Idle Valves / Anti lag Valves
Old Oct 1, 2007 | 11:42 AM
WD Pro's Avatar
WD Pro
Default Idle Valves / Anti lag Valves
I have managed to get my hands on a large escort plenum and throttle body that has already been modified to suit a Dax chassis.
The elbow has a pipe fitted to run a remote idle / anti lag valve (standard valve fouls on one of the chassis members).
Which valves are people running for ‘remote’ use and how are you piping them up ?
I need the valve to run with the standard ECU as I have a L8 which will get a MSD als conversion / map.
I already have a good condition standard idle valve so if that can be mounted remote I guess that would be the best situation ?
Cheers for any input.
WD
Old Oct 1, 2007 | 02:55 PM
GARETH T's Avatar
GARETH T
people use the lancia remote idle valve holder
Old Oct 1, 2007 | 03:40 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i believe that fiat coupe turbos also use the same ISCV, which may have a more useful mount for you
Old Oct 1, 2007 | 03:45 PM
kjc300's Avatar
kjc300
http://www.webcon.co.uk/Downloads/ACM-4.0a-S.pdf
page 72
Old Oct 1, 2007 | 03:46 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
IIRC the lancia inlet/outlet isnt that big, may not be ideal for effective ALS.
Or maybe i dont IIRC
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
routemaster
Sep 7, 2015 05:27 PM
