Oil hose on cossie
Old Sep 30, 2007 | 02:33 PM
NoNoCos's Avatar
NoNoCos
Default Oil hose on cossie
Hi !
In this picture we can see a flexible pipe name 8.
I want to know were we fit this in bloc ? And how we do ?
Do I make a hole and solder a connection in the sump ?
Thanks. Regards
Old Oct 6, 2007 | 09:13 PM
killerscum01's Avatar
killerscum01
GGR have their own particular way of doing this, which obviously works for them.
But most Breather systems i have had or seen, have the drain on the turbo side of the engine there is a plug in the block towards the back of the engine, you take that out and put a tube fitting in and connect to the bottom of the seperator, the two ongine breathers (if you have the rocker cover one fitted) go to the top of the seperator, and the one left on the seperator goes to the catch tank.
Hope this helps
By the way the pipe 8 thing is actually the pipe size -(dash)8
Cheers: Bart
Old Oct 9, 2007 | 10:10 AM
NoNoCos's Avatar
NoNoCos
Okay thanks
Old Oct 9, 2007 | 11:43 AM
THE RADMAN's Avatar
THE RADMAN
when using the ggr one, you remove the standard flame trap and use its return to sump for that hose
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
Thanasis
Sep 7, 2015 07:33 PM
hopper350
Sep 4, 2015 12:53 AM
