Boost pressure issues
Old Sep 30, 2007 | 12:25 PM
andyorion's Avatar
andyorion
Default Boost pressure issues
I have a question about boost pressures, since fitting a full twin pass front mount intercooler the boost pressures are vastly different in behaviour to how they where when the charge cooler was fitted. What happens is when accelerating through 2nd the boost pressure peaks at 20 p.s.i and drops gradually as the revs increase to around 14 p.s.i then in 3rd the boost pressures will again peak at 20 p.s.i then drop off to around 16 p.s.i as the revs increase then when in 4th and 5th the boost peaks at 20 p.s.i and drops and holds 18 p.s.i. not dropping off like it does in the lower gears. I thought at first the actuator I had may have been weak so I have replaced the actuator with a Garrett -31 and just fitted a brand new amal valve with no effect to the boost pressures. I have checked the boost hoses and hoses from the compressor wheel to the actuator/amal valve and they are all secure with no leaks. Is this boost drop in the lower gears due to the increase in area that the turbo has to fill since fitting the intercooler, as it didn't do it with the charge cooler fitted, and would it be worth me ditching the amal valve and fitting a proper electronic boost controller? If so which one should I go for?
Any advice would be greatly appreciated,
Cheers in advance
Andy
Old Oct 1, 2007 | 06:48 PM
andyorion's Avatar
andyorion
Any one?
Old Oct 1, 2007 | 09:33 PM
mechanic28's Avatar
mechanic28
it will always hold more boost in the higher gears due to the engine load being greater
Old Oct 1, 2007 | 09:49 PM
andyorion's Avatar
andyorion
Oh ok so its normal then nothing to worry about.
Would the boost controller over come this or would it be exactly the same and therefore a waste of time to fit one?
Old Oct 3, 2007 | 11:34 PM
andyorion's Avatar
andyorion
Sussed it, actuator and compressor housing vacumn pipes were on the wrong way round at the amal valve.
Old Oct 5, 2007 | 11:17 AM
Yura's Avatar
Yura
By my opinion maybe your westgate not enough opened? You have more gases at higer gear, and your gate have not enough capacity. Try to increase travel of your westgate actuator, it increase opening level of your gate, and more gases may passed through it.
JK12
33
Apr 26, 2021 12:09 PM
timsrs
Nov 13, 2018 11:48 AM
Mark_
14
Jan 16, 2016 05:27 PM
Russ Payne
Sep 25, 2015 08:29 PM
Marino
Sep 12, 2015 11:10 AM
