smoking escort ahh
Old Sep 27, 2007 | 05:17 PM
musicman1's Avatar
musicman1
Default smoking escort ahh
i have just brought an escort combi with the engine blown so i have coverted it to a 1.8 zetec bottom end with uprated cam new oil pump ect. but i have had it on the road 1 day and it smoke blue smoke when you change gear and deaccelerate but not when its on boost i am only running 4 psi at the mo. its an original 88 turbo with alot of play in the shaft. but could it be sucking oil through the valve seals when the engine deaccelerates. also another problem the cam is quiet noisey on tick over but fine when you rev it up. thanks rob
Old Sep 28, 2007 | 01:00 PM
SafeChav's Avatar
SafeChav
Sounds like it could be the turbo to me......does it smoke on idle?
Old Sep 29, 2007 | 10:41 PM
musicman1's Avatar
musicman1
it smoke on idle but not on boost rob
Old Sep 30, 2007 | 10:13 AM
ajchopper's Avatar
ajchopper
Sounds like the turbo seals.On tick over theres no presure on them so they will let through oil.Thats why it dont smoke on boost..Hope this helps..
Old Oct 1, 2007 | 10:21 AM
SafeChav's Avatar
SafeChav
right........if it smokes on idle you could try what im about to suggest......
If you block off the oil feed to the turbo that will stop oil entering the turbo, so if it is the seals producing the smoke this should become evident, but under NO CIRCUMSTANCES should you drive the car as you will do some serious damage.
The turbo spins about 4-5rpm at idle and as long as you dont leave it idling for an excessive amount of time it won't cause any damage, and should give you a lot better idea as to where the fault lies.
Old Oct 2, 2007 | 11:39 PM
musicman1's Avatar
musicman1
more news from the smokey escort i have done away with the turbo but getting the boost pipes stright from the fuel injection unit to the engine and it still smokes. when you start it up it is fine but when you go on a 2 or 3 min drive it starts smoking bad it maybe my rings or the oil breather i have canged the valve seals many thanks rob
Old Oct 5, 2007 | 12:49 PM
SafeChav's Avatar
SafeChav
Compression test it is then!
And while i think of it.........the turbo is no longer in the equation at all?
So no exhaust or boost side connected into the engine?
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
turbowag
Sep 3, 2015 08:07 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
Bighandsuk
Sep 2, 2015 05:23 PM
