Power estimate limits of a 56mm 'restriction'...
Old Sep 23, 2007 | 11:09 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Default Power estimate limits of a 56mm 'restriction'...
Say on a 2 litre, 4 cylinder engine you had a plenum with a narrowest diameter of 56mm on the entry - and it couldn't be opened out any more...
At what power would it 'cap' at?
Old Sep 23, 2007 | 11:10 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Slightly off topic but what is happening with your Escort Will? I haven't seen any updates for a while.
Old Sep 24, 2007 | 04:02 AM
GARETH T's Avatar
GARETH T
alot more than you think
Old Sep 24, 2007 | 07:54 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
You can only come up with an absolute figure if its before the turbo really, after the turbo its going to depend on the turbo itself.
Old Sep 24, 2007 | 08:00 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Default Re: Power estimate limits of a 56mm 'restriction'...
It's going to be a bit of a restriction at 500bhp, you'd be better off with a 60mm one. You'd be seeing gas velocities in excess of 500ft/sec with the 56, and ideally you want to keep it 350 ish. It depends on so many things. Ultimately yes, you could do it, if you had a turbo big enough to push it through.
Old Sep 24, 2007 | 08:43 AM
Karl's Avatar
Karl
Norris Motorsport
A 56mm throttle will give no relative restriction at 500bhp on a turbocharged 2.0litre engine. (I say relative as every component has some restriction, just that going larger than 56mm won't give a power increase)
Max power potential of a 56mm throttle is arguable but I have run engines in excess of 650bhp using one.
Old Sep 24, 2007 | 08:45 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Ultimately you shouldn't need a TB larger than the outlet of your compressor
Old Sep 24, 2007 | 08:51 AM
Big Will_'s Avatar
Big Will_
Well it's the Focus WRC Plenum that i'm using which i know is designed for balls out torque and not big bhp - the ID of the entry is 56mm prior to the split runners and i'm using 45mm Titan Roller Barrel ITBs to join it to the head...
I'd like to think it'd do 500bhp
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Iain Mac
Sep 30, 2015 09:39 PM
SMILER258
Sep 28, 2015 09:04 AM
