RATTLE ON MY 4X4
Old Sep 23, 2007 | 03:55 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Default RATTLE ON MY 4X4
when im slowing down in 4th gear there is a rattle or worst a grinding noise and its pitch as you might call it is in tune with the engine.
its only in that gear but when i put my foot down on the accelarater not fully i might add it stops and when i put the clutche in.
any idea? cheers
Old Sep 23, 2007 | 07:50 PM
messcortmk6's Avatar
messcortmk6
can you please describe it agai, i havent fuly understoood it.
but if its like a grinding/rubbing sound rather than a rattle its the clutch. does it not happen just under idle?
definately only in 4th?
Old Sep 24, 2007 | 11:00 AM
kosienutter
yeah its only in forth gear
the car is a saph cossie too which i should have mentions
dont know what you mean about the idle thing shipmate
do you mean when the car is moving or when the car is staionary
Old Sep 24, 2007 | 12:01 PM
messcortmk6
yeah.
does it happen when moving or still or in fourth with foot on clutch and still.
this is a really awkward one to be honest. are you sure its no problem and as all of us do we make the smallest problems and think theyre huge?
Old Sep 25, 2007 | 03:51 PM
kosienutter
IT ONLY HAPPENS WHEN MOVING AND ONLY IN FOURTH BUT IT STOPS WHEN I PUT THE CLUTCH IN
IT LEADS ME TO BELIEVE ITS THE GEAR ITSELF
THE OTHER BIZZARE THING IS THAT IT SOUNDS LIKE ITS COMING FROM THE REAR DIFF
Old Sep 26, 2007 | 08:33 PM
ickey818's Avatar
ickey818
I had a similar problem to this on my 4x4 saph. When in 4th gear and on overrun I could hear a grumbling noise coming from the transmission. As soon as I accelerated or dipped the clutch the noise would stop.
Tried to pin point the nosie with the help of a couple of mates, they both swore the noise was coming from the rear diff. Had diff rebuilt by DOME and new rear CV joints on the driveshafts, also changed centre bearing on rear prop but grumbling was still there. Gave up in the end and just lived with the grumbling noise for 6 months.
Last month I changed the front wheel bearings and the grumbling has now completly stopped
Going to change rear bearings next month just to be on the safe side.
Old Sep 27, 2007 | 10:11 AM
kosienutter
b****r were they expensive?
hope it sorts it out on mine
cheers bloke
Old Sep 27, 2007 | 05:55 PM
ickey818's Avatar
ickey818
Wheel bearing kit was about £35 per side, fitting them can be a pain as I found out!!
Old Sep 27, 2007 | 06:57 PM
kosienutter
nice ill go and get some soon then
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
