cvh heads
Old Sep 23, 2007 | 09:27 AM
juffer's Avatar
juffer
Default cvh heads
i have a 1.4 ported polished and gasflowed head. will it fit on my 1.6?
are the valves the same size?
Old Sep 25, 2007 | 09:53 PM
paconassa's Avatar
paconassa
I will fit if you have flat top pistons....
But the valves are both smaller, so I doubt its better than a std 1.6 head (flow wise....)
good luck!
Old Sep 26, 2007 | 10:07 PM
djmillsy's Avatar
djmillsy
Fife Radge
im sure the heads are smaller adn its the 1.6 adn 1.8 you can swap i may be wrong and it could be the 1.6 and 1.4
Old Sep 27, 2007 | 06:32 AM
JesseT's Avatar
JesseT
1.3 and 1.6 have the same bore and interchangebale head. The 1.3 has a smaller exhaust valve and slightly smaller chambers.
1.4 has a smaller bore than these two and in addition has a smaller intake valve. The 1.4 also has the arse-shaped combustion chambers and needs matching pistons or the CR will be miles out.
I wouldn't bother.
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
