group A fuel pump
ok just removed my fuel pump from my 2wd sapp and it has the following on it bosch 0580254941 is this a standard one??
also thinking of getting one of these baileys oil catcher thingys
are they any good?if so how easy to fit?any drilling required?
and any one got any light blue injectors for sale?
and .55 housing?
please pm me if u have any of items above cheers
and .55 housing?
Originally Posted by Jasesapphy
yes very straight forward, and make a loom
Steve.
The cossie wiring is a bit old now, so any shortfall could have disastrous consequences, best to rewire through relay, easy to do about 2 hours work, there is already a nice hole up behind the rear seat just right for a relay holder, plus as an added measure take relay out at night etc.
This is what I did using the oe wire to trigger relay, so still goes through cut out etc.
Use 28/030 wire as this is more than enough at 17.5 amps continuous, the group a use 13 amps@12 volts.
The std pump is good for around 380 bhp, group a ones will need a connector for the fuel side.
Matt Lewis sells these ebay or 01922 692424.
going to check voltage today
does matt lewis take debit cards now?last time i tried he did not
take he is shut on saturdays?
oh yeh do the light blue injectors have ford stamped on them??
does matt lewis take debit cards now?last time i tried he did not oh yeh do the light blue injectors have ford stamped on them??
The part number for light blues is 0 280 150 400-850
Steve.
cool just there is a set on ebay emailed the seller they have said they have got ford stamped on them??says light blue injectors dont look dark blue like in 4x4?but thay have a diff serial munber to what u have put so guess they must be the 4x4 standard ones
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ME:X:RTQ:UK:11
They are from a US spec FORD as these are stamped with FORD as well as Bosch.
The 0280150947 flow 254.9CC/min, they will KILL your engine big time.
The 0280150803's flow 389.9CC/min, just for comparison.
The add is complete lies and bollocks.
The injectors for sale are from a FORD TRUCK(pick up) 5.0L/7.5L, but it uses 8 injectors to supply the fuel, and the weediest ones make less than 300 on 8 of these.
JK12
33
Apr 26, 2021 12:09 PM
