HELP- Cosworth ISCV wire colour ???? NOW SORTED
Just took the connector off to fit another one, went inside, came back out and forgot which wire goes which side
Looking down on the ISCV from the front of the car as fitted into the car, does the red/black wire go on the left or the right side of the ISCV
help much appreciated
cheers
PAUL
cheers
PAUL
Well I just connected it all back up as per frogs description and she is running sweetly again from cold - the original connector felt loose and I thought that may the problem, and it appears to have been the case
POLARITY DOES MATTER.
On 4x4 and retro fitted idle valves, they have a voltage protection diode
within the valve and if you wire it backwards it will NOT work.
(If wrong, it will effectivly short out and eventually damage the ECU)
Some valves do have a + mark on them but not all.
If it does not work, try reversing the polarity but only make a short duration
test time to prevent ECU damage !
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
