Mk5 EFI Escort fuel pump sucking up air when cornering....
Hi peeps, got a slightly annoying problem that when I take a hard right turn for more than about 2 secs the fuel pump is heard to make a very strange speeding up noise and obviously the engine drops speed at the same time.
As soon as the car straightens up or on any left hand turn it's fine.
Bit of info on the car at the mo...
It's a 1993 Escort to which i've fitted an EFI Fiesta RS turbo engine.
I've changed the fuel tank (it was only a carb. 1.6 before) to one which I was led to believe is from a MK5 XR3i with integral fuel pump. The tank looks pretty much new in appearance too!
The only way it runs ok when cornering is if the tank is pretty much full.
Would fitting some sort of swirl pot fix this?
As another thought is the pump in the tank adequate for forced induction, ie do ZT engine owners change their fuel pumps?
Any helpful hints would be appreciated.
Thank you,
Karl.
Thank you,
Karl.
hehe not a fiver, prob about £15 lol
not gonna change the tank as i'm not exactly rallying the car around...this is just doing some normal town driving and roundabouts, surely something isn't right....
kosienutter
31
Aug 22, 2015 09:55 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
