mk2 rs2000 cosworth sump????
can anyone tell me how much has to be cut off the cossie 2wd sump to fit beside rs crossmember as i dont want to butcher it to find it was wrong i've had a look on a few forums but still no luck dont think its much to come off but better safe that sorry
got it sorted AG MOTORSPORT are not to far from me did a great job converting it to big wing also for a good price i recommend him to anyone whos thinking of getting it done!! il try get a photo on before its fitted to block
yeah mate he was doing it when i went down to pick mine up, guy has some talent, he built a mk2 for a mate of mine bout 10 years ago cant beleive i never thought of him in the first place but nevermind got it sorted now going to fit sump today once i pick up the gasket very pleased with it so i am great job for the money!!
indeed he is il get some photos on this week some point heading to glasgow for parts just now. aint cheap sticking a cossie lump in i thought it would be easy but the amount of stuff you need to change is unreal better starting with a bare shell thats what i did. could have went on the road without a paint but i did the full shell anyway no point cuttin corners mine is 5 linked turreted gusseted fire walled etc etc ive been told by a mate with a gp4 mk2 that il be going through a few half shafts lol he has a n/a yb with quafie throughout half shafts etc an he still manages to snap them time to time lol defo the way ahead for any mk2 lol
Its not cheap if you had a 2wd donor saph it wouldnt be just as bad..My shell is mint it would be a shame to cut it up 5 linking it & would prob mark the new paint along the way,,,
my shell was mint also its a non custom t plate was red originally but now signal yellow didnt need painted but i thought i may as well since all the work being done, its turreted firewall'd gusseted bulkhead plates etc etc a lot of fukcing about to get the yb to fit none of the hoses fit etc etc its never ending im having problems lining everything up straight engine box prop its only the inside an underneath you need to paint but your right it will get marked some how i need the front of mine painted already an its not on the road yet wings inner wings but its getting there that sort of bhp knocks the shit out them always better seam welding etc i need to sell my van to buy front brakes coilovers an wheels spent a fortune on it but they only go up in price now so it aint that bad the thought that ive sold beige! customs mexicos for 500 makes me ill
i built a mk1 and it,s deffo fun you just need a bin ford part,s bin
4x4 manifold and spin the turbo round unless you have 4x4 turbo
if you have probs pm me since i,ve done one
yeah mate i cant get the bolts loose to spin the house on the turbo im waiting on my mate to get his oxy working try heat them if not il need to buy another turbo boooo!!!!
I've got a big wing sump for sale to suit mk2 with cossie/ std crossmember.
Ł100
got a small leak from one corner but very easy to fix compared to making a new one. just needs Tig or araldite
Ł100
i had a big wing sump made at AG MOTORSPORT matey its my turbo im having problems with cause im using the 2wd turbo on a 4x4 manifold it needs to be spun 180* to fit the pipes cheers tho. can you tell me what colour wires are what on the loom?? i dont have a clue what needs to be joined where to make the car run. got both looms fitted just need joined together
kind regards
kind regards
red/black (thick)=fuel pump
red/blue (thick)=batt +
black(thick)=ign switch
green(thin)= rev counter
brown/white(thin)=water temp
brown/green(thin)=oil switch
brown/red=ecu diag light
this is what i was told how the yb loom works??
im still to look at the mk2 loom so this is gobbldy gook to me but it cant be hard to sort?? fuel pump live, bat live, ignition feed,??? then the others are for gauges i think so by looking at it, the ign wire contacted to the live feed at the barrel, batt+ onto constant live feed, and pump wire ran to back of car for live pump? feed? ? then i take it i earth the pump of the shell??
again this is all in my head at the mo still to put into practice lol
if im wrong can someone let me know
i bit the bullet and got a big wing alloy number made its spot on now trying to wire it up at the moment dont have a clue
if anyone can tell me what i mentioned above is right please let me know
dont want to fook it up lol
have you wired the two looms together before ricky??
can you tell me if im on the right track????
cheers matey
cheers matey
cheers matey
cheers matey
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
James Porter
Oct 28, 2015 12:17 PM
Aug 14, 2015 07:29 AM
lockie
Jul 31, 2015 10:03 PM
