odd lambda problem..
Old Sep 18, 2007 | 06:02 PM
JanDK's Avatar
JanDK
Default odd lambda problem..
I see a figure on my laptop saying "lambda correction inv. in %" I am not sure what it means, but going up and down several times a sec (like it corrects) only when giving throttle so it boost from little to max this figure becomes constant.
Havent acutaly noticed this before, only now after fixing my tps that was broken. What can cause it to regulate like this all the time??
The lambda is very new.. so it should work. Everything ells works fine such as cts.
Old Sep 18, 2007 | 07:14 PM
Lamda(value) does move constantly, this is good as it shows it is working, when they get dodgy they stop moving or very slowly.
Old Sep 18, 2007 | 07:25 PM
JanDK's Avatar
JanDK
oh.. just never noticed it.. I can see the logic in what you says Thanks
JanDK's Avatar
JanDK
Old Nov 23, 2007 | 06:33 PM
mappindude's Avatar
mappindude
some systems need to see tps sensor to use lambda .
eg, at a certain throttle angle lambda sensor is active eg:at idle and up 30% throttle.
With a broken tps it probably defaults to ignoring the lambda sensor.
Old Nov 24, 2007 | 08:06 AM
JanDK's Avatar
JanDK
Oki... actually all these probs I had some time ago was cause by tps I had focus all the wrong places. But fixed now.
By the way.. I do understand the figures much better now... idle and when giving throttle.
Thanks
Indyrs
Dec 4, 2022 12:39 PM
timsrs
Nov 13, 2018 11:48 AM
155lee
Oct 24, 2015 11:11 AM
Si B
Sep 12, 2015 06:49 AM
