Manifold
Old Sep 15, 2007 | 05:16 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
Default Manifold
what will a four branch alone do to the standard engine? few bhp?
and will it help the cam im planning on putting in later?
thanks
Old Sep 15, 2007 | 05:37 PM
Wardy257's Avatar
Wardy257
What engine?
If it is a ZETEC there is no point as the standard manifold is good for 150 bhp. No point fitting cams to a ZETEC either as the standard cams are good for 170 bhp it is the inlet and mapping holding the engine back.
Old Sep 16, 2007 | 01:01 AM
blk-Mk5-zs's Avatar
blk-Mk5-zs
i meant to put the engine type
its a mk2 xr2, 1.6 cvh, i was thinking of the ashley 4 branch manifold.
Old Sep 16, 2007 | 06:33 AM
It will help more than you think, particularly mid range, as this will remove a step that ford put there for clean emissions, and will release some more grunt.
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
caprixpack
Sep 25, 2015 07:53 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
Si B
Sep 12, 2015 06:49 AM
