fitting RS500 3dr cossie wheels to a s1 erst
does anyone know what wheel bolts and washers i need to use to fit rear wheel drive ford wheels to fwd ford. So basiclly wannt fit rs500 wheels on an s1 but the rear bolts catch the shoes on the inside.
Spoke to speedshack and they said i need rear wheel drive bolts and washers to fit them
anyone know or heard about this as i wanna buy a set or2
cheers
cheers
Basically if you put the RS500 wheels on with S1 bolts, then the bolts will simply pull through the wheels, causing significant damage. You can buy bolts with different angled flanges on them, or do what I have on my cars, which is to convert them to studs. Then use normal alloy nuts as found on most Fords from 1990 onwards.
steerfromdarear
28
Jan 29, 2016 06:14 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
