Its Evo time!!
Old Oct 2, 2004 | 12:18 PM
Jon(m600)'s Avatar
Jon(m600)
Default Its Evo time!!
Thinking of buying an evo do any of you lads no what to look for and what mechanical problems they may have.
Old Oct 2, 2004 | 12:23 PM
cossymad's Avatar
cossymad
transfer boxes
Old Oct 2, 2004 | 12:27 PM
warleydaddy's Avatar
warleydaddy
cossymad,
transfer boxes
DEFFINATLEY!!!!!!!
2k MINIMUM for rebuild!!
Interior wears EASY in them
Pete..
Jon(m600)'s Avatar
Jon(m600)
Cheers chris got them Wheel studs you sent m8 I will be in touch m8
Old Oct 2, 2004 | 12:28 PM
Jon(m600)'s Avatar
Jon(m600)
Are transfer boxes a problem on standard evos
Old Oct 2, 2004 | 12:34 PM
cossymad's Avatar
cossymad
27000 miles on my mates 7
Old Oct 2, 2004 | 12:38 PM
Jon(m600)'s Avatar
Jon(m600)
Feck! Whats the 7 like as an everyday car chris cos thats the one im after
Old Oct 2, 2004 | 12:44 PM
cossymad's Avatar
cossymad
oh and his driveshafts whine like fuck
Old Oct 2, 2004 | 12:56 PM
cossymad's Avatar
cossymad
As std 300bhp out the box ain't bad, but they handle like shit
Old Oct 2, 2004 | 01:06 PM
Racey's Avatar
Racey
you lucky sod - good luck with the purchase and dont come on here boasting too much please!!
Old Oct 2, 2004 | 01:07 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
AFPMSLLOLROFLPMSL
Is that why Gary had a chap with a 500bhp Escos ask him what he had done to his (almost standard) Evo at Donington on National Day?? I can't think of ANY car on the road that handles better than the Evo. They are just SO rigid.
Tyres are something to be considered. The Standard Yokohama A-046's are incredible (they have VERY stiff sidewalls and excellent grip), but they are about Ł150+ each.
Old Oct 2, 2004 | 01:28 PM
Jon(m600)'s Avatar
Jon(m600)
So they handle then and are reliable (except transfer boxes)are quick off the mark and are rarer than scoobys.
Old Oct 2, 2004 | 01:29 PM
mattbibs's Avatar
mattbibs
at croft i didnt see anything that got past an Evo!
Old Oct 2, 2004 | 01:33 PM
cossymad's Avatar
cossymad
AFPMSLLOLROFLPMSL
Gary must have adjusted it then 'cause I have driven 2 and they were shit.
Old Oct 2, 2004 | 01:35 PM
ESCYSCOTT's Avatar
ESCYSCOTT
i did, steve scotts wrc escort cossie
Old Oct 2, 2004 | 01:44 PM
Ian M's Avatar
Ian M
use loads of fuel no matter how you drive them
Old Oct 2, 2004 | 01:57 PM
brad's Avatar
brad
the brakes squeal and as a general rule you only get 7 proper sidestep the clutch launches per clutch .
Old Oct 2, 2004 | 02:45 PM
bbigman2000's Avatar
bbigman2000
LOL lads lads lads,
Im a ex evo owner and MOD here www.lancer-evo.net
I know a little about evo's and the above is bollox
The engine is VERY VERY VERY dam good, the handling is second to none on tarmac and gearbox's transfer boxes and drive shafts are all very strong
Tuning is very easy, but MUST be done correctly
Fuelling is the main concern when modding.
The worst thing for going wrong is the AYC diff at the rear, it needs the oil changing every 3000 miles or so and must be done by a mitsu dealer or a specialist evo tuner like Mark Shead or Rc developments etc.
Other bad point on the evo 6 is the front brakes, they need upgrading, not through lack of size but through the design of the bell on the discs
the brakes only squeal with harder pads installed
clutches can last 20,000 miles or 60,000 depends a lot on driving style
check out our site above and have a look at the buyers Guide thats the best advice
you wont look back
Old Oct 2, 2004 | 02:54 PM
cossymad's Avatar
cossymad
bbigman2000 can you find out how to adjust, or tell me the camber on a 7 'cause the one my mate has.....which he has crashed 3 times now, back end breaking away ....drives like poo.
I have driven a 6 which I think was very good
Also the fuel usage IS crap ,and tank capacity is at least 10 litres less than cossies. Very annoying on the way to Germany when I used one full tank, and we had to stop twice for EVO boy
Old Oct 2, 2004 | 03:03 PM
bbigman2000
mate sounds like he has a problem with his AYC diff ? it will either be the pumps failed, or the ayc ecu is fecked up, there are pressure switches etc which fail fairly commonly especially when servicing is poor, as I say clean oils vital for this set up.
pop into our forum mate, we have a guy in kent who's very good Rich, make a post and he will help you im certain
like you say economy is bad, although when set up properly they aint to bad, mine was even worse than a gsr mine was an RS, tanks tiny
Old Oct 2, 2004 | 03:13 PM
Physio's Avatar
Physio
PMSL!! You've got me in hysterics mate That's gotta be the funniest thing i've ever read On a serious note... I've had loads of cossies & not one of (IMO) could outhandle the evo! Like Glen says the handeling is second to none
Old Oct 2, 2004 | 03:15 PM
cossymad's Avatar
cossymad
Would this be another reason why it whirs like mad....sounds like wheel bearing or somit.
I hate driving his, far to stiff and rigid and looks very unsafe driving along
Old Oct 2, 2004 | 03:22 PM
cossymad's Avatar
cossymad
OK I'll re-phrase.
My mates 7 that I have driven, and have watched him drive does not handle anything aswell as my Escort Cosworth which I am used to driving.
In my opinion, that is shit. I have been in the 7 with him when he has crashed .....twice on a stretch of road where I go much faster and smoother in control.
He also crashed in the wet on a bend behind me. I was doing 50mph, he was doing 30.
I have driven a 6. It was much much better than the seven. The 6 is not shit IMO
Old Oct 2, 2004 | 03:24 PM
Physio's Avatar
Physio
Ahhhhh ok mate i see The handeling on the Tommi Mak is better still than the normal 6
Old Oct 2, 2004 | 03:25 PM
Christian and Beccy
#1 in Spelling Club
You should try and jack one up!! If you jack one corner, by the time the wheel is off the ground, you have 3 wheels off the ground. They are VERY rigid.
Unlike a Cossie, where if you give it 3 pumps on a trolley jack, you can't open the doors!!
Old Oct 2, 2004 | 03:27 PM
Christian and Beccy
#1 in Spelling Club
BTW, the 7 has 2 front geometry settings that are fairly simple to change. One is for normal road use and one is a high camber setting for the track. I wonder if your mates car is set to that?? That will make it very skittish and unstable.
Old Oct 2, 2004 | 03:28 PM
cossymad's Avatar
cossymad
I have not driven a Makkinen edition although I know they do have different suspension and brakes which would help
Old Oct 2, 2004 | 03:31 PM
cossymad's Avatar
cossymad
I think my mates 7 has 3 settings.
1. Shit
2. Ditch finder mode
3. Antidive-preactive yaw diff uncamber/caster set telemetric-protronic, with optional dynamic stiff-diff.
I think his one is set to number 2.
Old Oct 2, 2004 | 03:55 PM
MATCOS's Avatar
MATCOS
@ cossymad
Old Oct 2, 2004 | 03:57 PM
Physio's Avatar
Physio
1. Shit
PMSL
Old Oct 2, 2004 | 04:16 PM
GaryEvo's Avatar
GaryEvo
1. Shit
i cant understand how anyone can say they dont handle
when i picked mine up for the first time the tyres were shagged and the alignment was miles out used to pull over over the road but never to the point i thought i was going to crash!!!!!
but i will say for someone whos never driven one before they do follow every bump in the road and also you feel EVERYTHING the car is doing as it only has 2 turns lock to lock on the steering
they do suffer with lift off oversteer more on roundabouts but i cant say the backend ever normally goes out off shape apart from the spin at donnington
hopefully ill get some video footage from snetterton on wed this week!!
Old Oct 2, 2004 | 04:17 PM
fordfan's Avatar
fordfan
Try here http://www.lancerregister.com/faqindex.php(If the link works)
Everything you need to know.
Fantastic cars In my unbiased opinion(not)
Had a stage 1 4x4 Saph before but an evo is a different beast much more of a rally car for the road.
Old Oct 2, 2004 | 04:54 PM
Dave Henshall's Avatar
Dave Henshall
the suspension arms have ecentric ajustable bushes in them to ajust the camber on the fornt and rear. had my evo 6 4 wheel laser aligned at RC developmetns - and i tell you what - it was literally like drinving adiffernt car, much more sure footed, more controlable, but if "playing" could be made to dance on command, tyre wear greatly reduced once all tracked up correctly aswell, is your mate still running the factory yoko hard as fcuk tyres, if so get them off and get some decent sticky rubber on, the ones they are shipped with are just no good over here in this cold climate.
only thing that ever went on mine was the turbo (which was replaced under warranty) but the cause was the copper who pulled me over reached in anshut her off RED hot, w@nker!
Old Oct 2, 2004 | 04:55 PM
Dave Henshall
http://www.lancerregister.com/index.php?styleid=4
Old Oct 2, 2004 | 05:31 PM
Jon(m600)'s Avatar
Jon(m600)
Just thinking of getting a car that doesnt make me go deaf,doesnt poison me with petrol and breather fumes and i can actually take my eyes off it without worrying it will be nicked/trashed
Old Oct 4, 2004 | 07:41 AM
Dave Henshall
thats not an evo then
Old Oct 4, 2004 | 08:10 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Gary - McDonalds roundabout .
Chris, properly set up Evos are exceptional cars, but as has been said, poorly set up ones are a pile of poo. I think Simon needs to get his sorted ASAP before it gets wrapped around a lamp -post .
Old Oct 4, 2004 | 08:28 AM
cossymad's Avatar
cossymad
Originally Posted by Gary @ APT
the alignment was miles out used to pull over over the road but never to the point i thought i was going to crash!!!!!...................
Macdonalds roundabout
I am starting to believe myself
