Drive Shafts
Old Sep 12, 2007 | 08:01 PM
focus 4x4's Avatar
focus 4x4
Default Drive Shafts
Im stripping my rear drive shafts to re furbish them, is it essential that i make a note of rotation and what side of the car the shafts came off? now stripped the shafts themselves look pretty much identical? any help is much appreciated. cheers
PS it would be wicked if anyone can post any pictures of some re furbished shafts.....
Old Sep 12, 2007 | 08:34 PM
ian sibbert's Avatar
ian sibbert
You should take note of shaft rotation pal, as when the are initally under load they do twist, consequently if you then switch rotation and load them the other way they twist back, twist further and snap....
Old Sep 12, 2007 | 08:47 PM
focus 4x4's Avatar
focus 4x4
Top man thanks for that, glad i made a note of rotation, ive decided to strip and re build thenm one at a time.
Old Sep 13, 2007 | 02:24 PM
focus 4x4's Avatar
focus 4x4
do the different markings on each end of the drive shaft significantly mean anything - ie inner or outside?
Neil Clark
21
Oct 1, 2015 07:02 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Bransby
Sep 11, 2015 09:12 PM
rsstav
Sep 7, 2015 04:43 AM
