will this fit??????
Sep 12, 2007 | 11:31 AM
will this fit??????
will a fiesta rs turbo egine go straight in my escort?
Sep 12, 2007 | 11:33 AM
ive got one in mine mate....
fiesta efi turbo engine with a t3 turbo off an escort..
Sep 12, 2007 | 11:37 AM
just the same engine innit block and head wise slots in just the same as your other one that comes out
Sep 12, 2007 | 07:10 PM
cool,, am collectin the engine 2nite, as i took my escort turbo engine out cuz its shagged, will my ecu work ok on a fiesta turbo engine?
Sep 12, 2007 | 09:26 PM
no unless you put your escort rs turbo head back on the fiesta block
Sep 12, 2007 | 10:28 PM
if u wanna run it on mfi u will have to swap the heads over as the inlet ports are different
Sep 12, 2007 | 10:29 PM
ok, got the engine now, will i need ofab? (wat is ofab exactly an wat parts do i need 4 it) will i need 2 modify my loom? cheeRs
Sep 12, 2007 | 10:31 PM
Quote:
jus read it...........i want to swap over to efi, as the engine i jus collected is efi cheers
Sep 12, 2007 | 10:32 PM
if u wanna keep the the efi head and inlet then yeah u will need to run frst efi (ofab/ofac)at the least- do a search as there is lots on here covering the conversion
Sep 12, 2007 | 10:36 PM
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
