Another mk4 / 3 question
Old Sep 11, 2007 | 08:20 PM
tont2002's Avatar
tont2002
Default Another mk4 / 3 question
Hope this is the right place to ask this......
Just wondering how much of a S2 turbo (engine, box, suspension, e.t.c.) will bolt into an empty S1 mk3 shell.
chee-rs for ya help in advance
Old Sep 12, 2007 | 12:02 AM
antony215's Avatar
antony215
Escort Rs Turbo
Engine will go stright in box wont. Things like the struts,hub's,front brakes ect.. will fit not sure about the antiroll bars tho.
Old Sep 12, 2007 | 07:49 AM
JesseT's Avatar
JesseT
The front antiroll bars and their mounting locations are diffent in mk3 vs. mk4.
Radiator and intercooler are of different shape and have different fittings.
Gearbox mount was already mentioned.
Old Sep 12, 2007 | 05:55 PM
tont2002's Avatar
tont2002
So i can use so far......
S2 engine, loom,
S2 suspension, wishbones, arms, hubs e.t.c.
S2 front/rear brakes (inc handbrake??)
S1 gearbox
S1 front anti roll bar (will this fit into the s2 hubs??)
(Its having a custom rad and cooler anyway)
Thanks for your quick replies......
Old Sep 12, 2007 | 06:16 PM
JesseT's Avatar
JesseT
Yes for the handbrake (nothing different tough), yes for the front roll bar.
The mk4 loom will not easily fit the mk3, so it's better to just fit the KE-jet and ESC-II management looms. This means separating them from the main loom.
Old Sep 12, 2007 | 10:30 PM
tont2002's Avatar
tont2002
Planning on using the fiesta ecu and ofab loom (to get rid of the dreaded metering head). So just really going to be putting in a basic loom to get the car through an mot (lights, horn e.t.c.).
Gotta feeling the engine bay isnt going to look too pretty.
Also ive heard, that due to me running a s2 loom, i have to use a mk4 dash, for the clocks???
Cheers again
Old Sep 13, 2007 | 04:24 AM
JesseT's Avatar
JesseT
Cheers again
It's not only the clocks, but every other connector and circuit will be different. Do yourself a favor and get a mk3 loom.
Old Sep 13, 2007 | 06:33 PM
tont2002's Avatar
tont2002
Cheers JesseT
Would it be ok then to use a mk3 loom, and a fiesta engine loom, and splice the 2 together????
(im ok with the mechy side of it, but the elecy side is a bit confusing???)
Nice 1
Old Sep 14, 2007 | 06:19 AM
JesseT's Avatar
JesseT
That sound better, but just leave them separate and only connect the few wires between the looms that are needed, and those can be counted with the fingers of a single hand.
Old Sep 14, 2007 | 10:48 AM
jon@work's Avatar
jon@work
isn't the driver's side engine mount also different between mk3 and mk4 shells ?
Old Sep 14, 2007 | 01:39 PM
JesseT's Avatar
JesseT
Might be slightly different but totally interchangeable. That is, the mounting points are the same on the block and on the shell.
Old Sep 16, 2007 | 05:38 PM
tont2002's Avatar
tont2002
Right think im finally getting there now, this is looking like a rather big shopping list...... lol.
No doubt once i start putting it all together, you will see a lot more of me begging for help......
Cheers again.
If theres anything else you think i might need???
Its not going to be used as a road car, just a track car, but want it road legal and all registered, to get to and from tracks.....
Thanks all for your help, especially JesseT
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
