AVO Coilovers for sale
Sep 10, 2007 | 09:17 PM
Brand new, never used.
AVO Coilover kit for 4x4 Sierra Cosworth or Escort Cosworth.
£450 ono
Sep 10, 2007 | 09:59 PM
are thay the same on 2wd as 4wd are thay :?
Sep 10, 2007 | 10:03 PM
Rear fitments are defo the same.
And Im pretty sure that the 2wd fronts are interchangable too...
Std stuff may have slightly different front struts, but Im not 100% sure.
But this kit is for a 4x4. Im just guessing, but pretty sure they fit a 2wd too. Im sure others with more experience with these cars could clarify.
Sep 10, 2007 | 11:11 PM
4x4 front coilovers wont fit 2wd hubs as the 4x4 bodies are slightly fatter.
ie the 2wd hubs have a smaller hole for the coilover to fit into.
Sep 11, 2007 | 12:17 AM
Thanks for clearing that up Saint....
4x4 only it is then.
Sep 11, 2007 | 01:36 AM
Hello There..
Only just registered with the site.
Been after a set 4 a while now..
How much to post to Staffordshire, UK
Thanx
Jodie
Sep 11, 2007 | 06:10 PM
Id guess at £20 postage...
Oct 31, 2007 | 12:52 AM
Oct 31, 2007 | 09:22 AM
hi could you tell me what spring rates are fitted to the front and rear?
Oct 31, 2007 | 06:00 PM
I'll check later. But it will be whatever Avo supply in their kit.
Nov 2, 2007 | 11:05 PM
Quote:
Front springs are marked E12-200
Rear springs are marked E9-300
So I assume thats 12" open length, 200lbs/in etc
Nov 11, 2007 | 10:51 PM
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
Mr S1
20
Sep 27, 2015 04:06 PM
