poor running focus
Old Sep 10, 2007 | 08:25 PM
GARY1978's Avatar
GARY1978
Default poor running focus
hi all
i keep breaking down in the focus it feels like fuel starvation i keep changing the fuel filter and there black stuff in the petrol and it will drive fine too i boot it and it starts all off again i broke down 3 times on the way to this morning
Old Sep 11, 2007 | 01:40 PM
Has it just started to do this ?
Have you changed the fuel filter recently ?, if not that would be worth a go, does it splutter to a halt and then start right away or ?
Old Sep 11, 2007 | 05:27 PM
GARY1978's Avatar
GARY1978
to the above yes i have changed the fuel filter then i drove it home from work i hit the rev limiter and it started again my mate said it could be a ecu fault
Old Sep 12, 2007 | 05:32 AM
Almost defo not a ecu fault, this may sound odd but look for corona discharge on the plugs, as I have known this before on the zetecs especially the early ones.
Are you using BOSCH plugs by any chance, if you are bin them.
Old Sep 12, 2007 | 09:16 PM
GARY1978's Avatar
GARY1978
i was told to change the water temp sensor as its a comman fault with focus so ones on order £14.10+vat at that price its worth a try just changed the plugs one month ago with ngks but had the motorcraft ones b4 and was the same.
Old Sep 14, 2007 | 06:19 PM
GARY1978's Avatar
GARY1978
i almost did ys that i have changed the fuel filter just in case
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
BIL N KEL
12
Aug 27, 2015 03:26 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
