low comping s2.
Old Sep 10, 2007 | 06:54 PM
OLDSKOOLRYAN's Avatar
OLDSKOOLRYAN
Default low comping s2.
hi, in a previous post i asked if it was possible to low comp my standard pistons for my s2.
lots of people have said it is ok.
but how much needs to be machined/skimmed off the top?
is it as simple as that?
hope you can help cheers
Old Sep 10, 2007 | 07:29 PM
JesseT's Avatar
JesseT
Depends how much of a problem do you have with knocking? Don't take any of you don't need to.
If you do take, take form the center only and not the furthest 5mm, because you don't wan't to shorten the distance fron the top of the piston to the first piston ring.
Old Sep 11, 2007 | 10:00 PM
SafeChav's Avatar
SafeChav
The amount you take off all depends on what CR you are looking to run.
If you go too mad skimming them it will be extremely dull to drive unless you're aiming for massive power and running a seriously big turbo.
And as Jesse says with regards to the area of the crown you skim.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Tank Mike
Sep 26, 2015 08:07 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
