Remove rear wheel drum
Old Sep 6, 2007 | 04:51 PM
S4[UK]'s Avatar
S4[UK]
Default Remove rear wheel drum
Hi.. Im needing to take the rear drums off my 95 5 door escort to do some inspecting
How to take the drums off?
Old Sep 6, 2007 | 06:31 PM
antony215's Avatar
antony215
Escort Rs Turbo
Put something infront of the front wheels jack the back up take the wheel off let the handbrake off then there will be a screw to hold the drum on undo that then the drum should just pull off (sometimes they are a bit stiff to get off tho )
Old Sep 6, 2007 | 08:11 PM
tonto's Avatar
tonto
Mate.Take the wheel off then on the back plate behind the drum are 4 17mm bolts.undo the bolts and remove them.then the drum and hub can be removed.DO NOT remove the centre hub nut.
Paul
Old Sep 6, 2007 | 08:32 PM
jawanne's Avatar
jawanne
hi take the wheel off then the crown nut thats in the middle off the drum and make sure that the hand brake is off and the car in gear so the car doesnt fall on yea
Old Sep 7, 2007 | 01:35 AM
S4[UK]'s Avatar
S4[UK]
Paul
Can i see the bearings doing that? i need to see if they are broked
Old Sep 9, 2007 | 05:30 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
Paul
why would you take the whole stub axle off if he wants to see the bearing or get the drum off?! as said just undo tho nut. whats it doing?
Old Sep 12, 2007 | 07:09 AM
S4[UK]'s Avatar
S4[UK]
Paul
tis making grinding noise which gets worse the faster I go
original
Apr 28, 2026 05:20 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
marky_g
Aug 3, 2015 04:45 PM
