boost
Old Sep 5, 2007 | 09:50 PM
will4hattie's Avatar
will4hattie
Default boost
hi my fiesta standard i think other than full exhaust k&n and bailys dump valve what boost can i run safely or what modifications are the best for not too much money to make noticable differnce in performance thanks again will could u tell me in bar and psi many thanks will
Old Sep 6, 2007 | 01:54 PM
jrs's Avatar
jrs
Stage 1 chip is your best and cheapest with a rolling road tune you wil be able to run around 12psi i wouldn't up the boost on a standard frst it's not worth it
Old Sep 6, 2007 | 07:15 PM
Oranoco's Avatar
Oranoco
Was just about to say 165 chip would be my suggestion. Beat me too it
Old Sep 6, 2007 | 10:29 PM
will4hattie
cheers fellas so u jus get the chip fit it then get it rolled and set up and should run 10 or 12 psi also where do u get the chip from and what one should i get the 165 or is there a 195 cheers
Old Sep 7, 2007 | 06:07 AM
jrs's Avatar
jrs
It you go for the 195 you will need fuel pump and injectors. When fitting the chip it is very easy you will need to take the ecu out the open it up to clean all the white grease off where the chip is pluged into. I use brake cleaner on a clean cloth onnce it's all clean refit ecu the plug the chip in never play with the chip when the car is on or and dash light's on as this will fcuk the ecu up
Old Sep 7, 2007 | 09:27 AM
will4hattie
how could i tell if my cars already chipped if not where could i get the 165 one from cheers
Old Sep 7, 2007 | 03:33 PM
jrs's Avatar
jrs
Open the pass/door and get down in the footwell and look up behind the dash you will see the ecu you would see a chip in the bottom of the ecu if it has one if not look on ebay or on www.fiestaturbo.com you are looking about £60-100 second hand new there about £200+
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
