cooling mt75 viscous coupling
Old Sep 3, 2007 | 07:38 PM
Mark_1's Avatar
Mark_1
Default cooling mt75 viscous coupling
Last year i experienced problems with the viscous coupling during trackdays, as it overheated and less and less power went to the front wheels, which resulted in me having to drive without wheelspin for a lap to let it all cool down.
since next car will have almost twice the power i need to cool down the vc.
so i bought a tilton electric oilpump and i have some oil radiators lying about.
But the most obvious way to install this is to take the hot oil from the drain plug run it through the pump and radiator and back in the filler hole.
But the most efficient way would be to let the cool oil rain down on the vc.
Now there is a black pipe right above the vc which i dont understand the purpose of but i do recon i could put it to some use.
Has anyone done this and can explain how they did it?
Old Sep 7, 2007 | 06:37 PM
Mark_1's Avatar
Mark_1
anyone?
Old Sep 7, 2007 | 06:57 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
I was going to use the rear oil cool setup off of a s14 rear diff setup....
Its basically a cooler, sensors, pump all set up to activate when the temp gets to a certain temp (probably adjustable by using diff sensor)
Its worth a looking at... breakers only want 100 quid ish for the whole lot.
Dan
mjonathan24
Oct 29, 2015 10:39 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Iain Mac
Sep 30, 2015 09:39 PM
deathrider666
Sep 28, 2015 06:12 PM
