timing up 2wd engine
Old Aug 29, 2007 | 11:00 PM
cos84's Avatar
cos84
Default timing up 2wd engine
Can someone give me details of the precise marked positions of the crank and dizzy pulley when timing the engine up.
Thanks in advance!
Andy
Old Aug 30, 2007 | 05:35 AM
Aaroncast's Avatar
Aaroncast
AND THAT CAR WOULD BEEEEEEEEEEEEEEE-????????????????
HARD TO ASSIST WHITHOUT A CLUE!!!!!!!!!!!!!!!!
Old Aug 30, 2007 | 05:38 PM
cos84's Avatar
cos84
yea car might help!
2wd sapph cossy.
cheers
andy
Old Aug 31, 2007 | 06:19 AM
Cams pointers, face inwards towards each other and along the join between the head and cam cover.
Dizzy/jackshaft, dizzy rotor arm must have the scribe mark on dizzy body dead central in the rotor arms "sight".
Don't worry if jackshaft mark does not line up as it is the rotor arm that is important, and it may not have been timed correctly before, but it does not amke any difference so long as rotor arm is in line.
Crank pulley is timed up on the LUG, NOT the notch!!
Lug must be in line with the pointer sticking out, the lug to use is the nearest lug to the marks on the pulley.
When setting tension push the belt towards the tensioner to take up the slack, whilst you turn the tensioner to suit.
Old Aug 31, 2007 | 07:44 AM
Mark_w's Avatar
Mark_w
Old Aug 31, 2007 | 07:09 PM
cos84's Avatar
cos84
thanks for your help
much appreciated
cheers
andy
Old Sep 1, 2007 | 09:31 AM
capriturbo's Avatar
capriturbo
Hi is this timing info the same for the 4wd big turbo engine? Thanks
Alex
Old Sep 1, 2007 | 11:27 AM
jon@work's Avatar
jon@work
Alex
Yes
DON'T FORGET : when tightening the adjuster, it needs to be turned clockwise to increase the tension on the belt. If you turn it anti-clockwise, then the belt can rub on the thermostat housing causing premature belt failure.
Bailes1992
Aug 16, 2015 07:14 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
