Puma with idling probs
Old Aug 25, 2007 | 07:18 PM
ZED's Avatar
ZED
Default Puma with idling probs
hi,
kinda new to puma ownership but old to ford ownership
My 98 1.7 puma with 69k seems to have developed a idle problem it comes and goes and the car never turns off the performance is fine too. the rev counter jumps up and down between 500-1500revs if i switch the lights on or a/c its sorts it self out again.
Any ideas about what it could be?
my wife put in super unleaded by mistake and as far as i can tell the problem has started since then..
the plugs and leads are new.
Have read other posts about it but no idea where these sensors talked about are and how to check them.
Any help will be very appreciated!
Old Aug 25, 2007 | 07:24 PM
Wardy257's Avatar
Wardy257
Clean the ISCV.
Old Aug 25, 2007 | 08:02 PM
ZED's Avatar
ZED
thanks for the reply.
where is it on the puma and whats best to clean it with.
Old Aug 26, 2007 | 07:45 AM
It should be on your throttle body im sure its held on by to 8mm bolts. Get some brake cleaner n give it a good clean out also try a bit of wd40 to give it a bit of lubrication.
Old Aug 31, 2007 | 10:27 AM
ZED's Avatar
ZED
Cleaned the ISCV and seems to have sorted it! Cheers mate!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gcfcos
59
Oct 6, 2015 05:04 PM
fordrallycar
Sep 30, 2015 07:57 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
