zvh running problem quick reply needed (pls)
my rs is not running right at the mo and i have noticed that the vacum pipe off the ecu was connected to the dump valve and a pipe comming off the t going to nothing sucking in air would of this made it hard to start and run rough
Originally Posted by Mixja
vacuum pipe off the ecu needs to be connected to the top of the inlet manifold...
Lee
Originally Posted by GARY1978
when you say bad starter do you mean taking about 25 seconds to fire up and maybe miss fire??? below 3000 rpm
and run abit lumpy
and run abit lumpyLee
no im running mfi at the moment what colour plug gos on the cold start vavle is it blue? plus i cant keep it running for long next door kick off it shaking their kitchen
matman
Sep 9, 2015 05:45 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
