Mk3 fiesta clutch
Old Aug 7, 2007 | 06:48 PM
Default Mk3 fiesta clutch
Hi there how easy is it 2 change a clutch on a 1.1 fiesta. Can u leave the drive shafts in n spin the gear box down 2 get at the clutch. Will the clutch pedal b ok n the self adjuster wont spring out will it.
Old Aug 7, 2007 | 07:39 PM
phill295's Avatar
phill295
yes you can swing the gearbox with the shaft in and not that had to do ur self hope that helps
Old Aug 8, 2007 | 06:32 PM
Sweet thats a great help does the clutch pedal have 2 b touched then cause they have a ratchet system on the pedal. Is there any way of stopping the ratchet system from shitting itself when u disconnect the cable.
Old Aug 8, 2007 | 06:44 PM
dave green's Avatar
dave green
Just disconnect the cable from the gearbox adjuster will be fine.
Sometimes you need some one to pull up on the clutch pedal when you pull the cable through to reconect it
Personally I always remove the shafts Gives you more room and no risk of damageing the oil seals, It dont take 10 mineuts to remve them
dave
Old Aug 9, 2007 | 06:46 PM
Or thanks mate it looks easy enough i will have 2 get a clutch n pull the box out. If im not spending money on my cossie im spending it on my work horse(fiesta).
JasonPD
Ford Focus RS
20
Oct 31, 2015 08:11 PM
liamT74
Sep 23, 2015 10:24 PM
Flateric_2002
Sep 15, 2015 08:41 AM
fordfiestamk3
Sep 11, 2015 12:52 PM
Brian
Sep 11, 2015 08:06 AM
