whats the bhp loss from..
oo ok mate..
well its 2wd..stage 3..t34.48..500 inter cooler..
i had it dyno'd last week..
the dyno sheet says 185.7 killowats which is 250bhp..
and it 367 lbs of torque..
and thats not at full potentiol as it was leaning out..
so basically i was just curious to know if that 250 would be around 330 at the flywheel..if that makes sense
Actually I kind of agree with you, based on the "energy cannot be created or destroyed" it means anything going into the box that doesnt come out has to be used up as either heat, noise or destroying the surface of the cogs in the box, and it does seem hard to see an entire 100bhp+ going that way, but none the less that is what happens it would appear.
Originally Posted by R5FORD
oo ok mate..
I dont see how it can be that much torque when its so down on power though, thats a BIG figure for at the wheels, far more than normal for a stage 3!
Have you got the whole plot you can stick up????
PassionFords Creator
Lovely topic... and this is what i am writing about for Fast Ford this month.
Ive personally witnessed figures of 35% quoted as transmission losses for a 4wd cossie from one "Specialist" in this country.
yes mate..
here it is..
it says 185.7 KW which is - 249.03 bhp
499.7 NW which is- 368.55 lbs
as you can see it starts to lean out so it wasnt run to its full potentiol..
i thought that torqur figure seemed very high..thats one reason iv posted this thread
here it is..
Originally Posted by graeme
I have allways x the figure at the rear wheel by 1.34 to get a estimate at the flywheel eg 250x1.34=335 on your case
Don't think so
Steve.
Its all bollocks, you see most the GTR lot quoting 150bhp+ tranny losses and shit.
In Oz, USA, anywhere worth a shit, they ONLY quote wheels, you go quoting flywheel and you will get laughed at.
We should stop all this flywheel bollocks in the UK too IMO.
Wheel power is for driving, flywheel power is for trying to show off when you cant prove it on the road.
Personally I would never trust any rolling road operative called "troy" I think thats the real problem here
Seriously though, those graphs and numbers are blatantly less accurate than if you used an etch a sketch
oo ok mate..
but than again i remember lee saying when i asked him what it was in bhp..he said around 300.. im well confused now
Don't think so
Steve.
It would if you get of your ass and get that 38 fitted Steve..
Hello from New Zealand chaps.
I also have a so called high HP figure for my run of the mill Stage 3, 2WD Sapphire down here.
It definately seems alot higher than some of the similar speced U.K Sapphires which is odd.
I've got a T34 .48 , Greens and a chip from NMS plus all the other stage 3 bits
Anyhow have a look at my Dyno chart and let me know what you make of it
ps. Ignore the Torque in the graph.
Cheers,
Ollie.
For those of you with poor eye sight it basically says , 300 HP at the wheel (225kw) at 26 psi boost.
Cheers,
Ollie.
i would be if it made sense..i drove it home and it clocked 10psi as the dump valve was relasing boost
..and it couldnt be run to full potentiol as it was leaning out bad.but by next tune it should be fine as iv replaced the filter..had a new pump and re wiring the fuel pump..
and iv got a spring for the d/v to cope with 25-30psi
..and it couldnt be run to full potentiol as it was leaning out bad.but by next tune it should be fine as iv replaced the filter..had a new pump and re wiring the fuel pump..and iv got a spring for the d/v to cope with 25-30psi
Originally Posted by KSA-Cossie
As long as you're happy with the power m8.
Agree Kev, i always go on how it drives on the road/track etc imo, numbers are numbers and sounds to me that they're wrong half the time anyway..
when the car was stage 1 ran spot on..
since i decided stage 3..
nothing but headaches
but than i think when its done it will be worth it
well i hope
well i hope
It could effect the power output if there was a problem with it (although it should be active at all at WOT on boost) but it wont make the machine the graph is from talk absolute bollocks like it has on your run.
