Clouted kerb in Sierra- Pulls to the left now- Whats broke?
Old Aug 6, 2007 | 09:22 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Clouted kerb in Sierra- Pulls to the left now- Whats broke?
As per title.
Hit it proper hard with front passenger wheel, dont pull to left too bad, still drivable, but let go of wheel and you off to the left pretty sharpish...
Wheel looks fairly straight, poss a bit toed out, unsure.
What am i likely to have broke, i presume you cant just knock the tracking out without actually bending summat, can you?
Jasesapphy's Avatar
Jasesapphy
Lower arm, possibly done ARB
Old Aug 6, 2007 | 09:24 PM
Oranoco's Avatar
Oranoco
Track rod end or lower arm. Don't have to put it out by much to make it drive like a base model Corsa
Old Aug 6, 2007 | 09:27 PM
discodenkelly's Avatar
discodenkelly
bounce, bounce, bounce
ARB I reckon. Did the same years back on an orion in the snow. Didn't hit kerb fast but gave it a proper clout!! It drove exactly how you describe the sierra
Old Aug 6, 2007 | 09:28 PM
coco16i's Avatar
coco16i
As said above, good chance the track control arm will have taken the brunt of the knock and probably bent, also check that the strut aint bent as bent one in my old 4x4 after hitting a kerb in the snow arseing around !! The hub takes a wallop and in turn bends the strut just above where it slides into the hub.
bud-weis's Avatar
bud-weis
Football Cwazy
track rod or TCA i'd imagine....nothing too major i wouldn't have thought, unless you've twisted the inner chassis mount for the TCA..but i doubt it.
Old Aug 6, 2007 | 09:33 PM
Dave Parker's Avatar
Dave Parker
that would be my vote
Old Aug 6, 2007 | 09:41 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
oh fab cheers lads, you think itd be easy visible once jacked up n wheel off, or it gonna be a case of trial and error fitting?
Old Aug 6, 2007 | 09:55 PM
Dave Parker
you might see slight kink where strut goes in hub but better take it out and look properly
Old Aug 6, 2007 | 09:56 PM
Jasesapphy's Avatar
Jasesapphy
ARB more difficult, can look spot on but be out by a few mill, lower ar usually easier to spot
Old Aug 6, 2007 | 11:15 PM
col cos1's Avatar
col cos1
done it defo track control arm
Old Aug 6, 2007 | 11:17 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
i dont see how the ARB can cause that like people are saying, sounds like track control arm to me.
Old Aug 6, 2007 | 11:21 PM
NUTS RuS's Avatar
NUTS RuS
Steering arm or TCA
Old Aug 6, 2007 | 11:36 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
TCA eh? well thats not a bad thing really, cant be hard to get one of them...
im banning myself from streeto tho i think, kerbs hurt
Old Aug 6, 2007 | 11:38 PM
Chip's Avatar
Chip
If its TCA or steering arm, you will get it more or less back how it was just by adjusting the tracking.
Old Aug 6, 2007 | 11:42 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
ah wicked, that sounds cheaper
its only slightly out as it is, my S12 pulled more to the left than this, but this sierra handled good before i just fucked it, so would prefer to make it drive ok again
Old Aug 7, 2007 | 12:13 AM
NUTS RuS's Avatar
NUTS RuS
Go out and clout the other side
That will balance it back up - Job done
Old Aug 7, 2007 | 06:36 AM
TCA they are made of plastescine.
Old Aug 7, 2007 | 08:02 AM
foreigneRS's Avatar
foreigneRS
Testing the future
TCA - you could get it tracking right by adjusting the track rod, but your castor will still be out. replace it, easy job
Old Aug 7, 2007 | 08:13 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it's either going to be:
tracking, nice and simple
bent strut, nice and simple
bent tca. nice and simple
track rod end, nice and simple
bush on the arb/tca pushed out, again, nice and simple
bent steering arm, not so simple
bent crossmember, again, not so simple
top mount popped through, simple
amongst other things
then again, it might just be your wheel that's fooked
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Fiddy
21
Sep 29, 2015 06:10 PM
