st24 estates- opinions
Old Aug 2, 2007 | 10:15 AM
Tank Mike's Avatar
Tank Mike
Default st24 estates- opinions
looking at getting one of these.
anyone got one??
whats it like???
is there anything i should look out for??
thanks
Old Aug 2, 2007 | 01:50 PM
bookwyse's Avatar
bookwyse
Not got the 24 estate got its big brother the 200 estate.
Standard things to look out for are:
Waterpump, prone to breaking and taking headgaskets out,
Lower wishbones, same as a Cougar and Ford only part at circa Ł180 EACH
Rear bumper unique to the ST estates and like rocking horse shit.
Good points
Look good,
go well,
some mods to make them go even better.
Can be made to look like mine:
Jeff
Old Aug 2, 2007 | 03:13 PM
Tank Mike's Avatar
Tank Mike
thanks mate, looks
Old Aug 2, 2007 | 03:22 PM
Tank Mike's Avatar
Tank Mike
is it just the ecu that gives the power or is there other engine differnces between the 24 and the 200
Old Aug 2, 2007 | 03:35 PM
bookwyse's Avatar
bookwyse
TRhe 200 uses diffrent pistons, cams, lower and upper inlet manifolds, throttle body, airbox and exhaust.
The manifolds and throttle body can be found on EBAY quite often..
If you want to chat about them feel free to give me a ring on 07816 165711.
The estate has been rolling roaded at 243BHP as opposed to the 202 standard and then 167 that the ST24 and standard V6's push out.
Jeff
Old Aug 4, 2007 | 07:50 AM
bluescortcossie's Avatar
bluescortcossie
thing to look out for on the st24/st200's are :
as said above , the water pumps break up as the fins are plastic ! make sure its replaced with a metal unit.
head gaskets go whenever they feel like it
exhaust manifold gaskets tend to develop a blow and are a bitch to change
other than that they are pretty good / strong cars
as for improving the power (st24) get a filter / exhaust / chip and a st220 (mk3) throttle body and have some fun !
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
Topjoe9
Sep 12, 2015 09:50 AM
Mark Mawson
Aug 31, 2015 07:09 PM
