will a xr 4x4 box fit straight into my cossy-any differences
Old Jul 28, 2007 | 07:45 PM
BIGMATT1's Avatar
BIGMATT1
Default will a xr 4x4 box fit straight into my cossy-any differences
The gear box in my saff has died and ive been offered a xr 4x4 box, just wondered if it will fit and if anything need swopping over, any help much appreciated, cheers matt
Old Jul 28, 2007 | 08:19 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's a 2.0 box it's almost exactly the same bar the output shaft on the rear being shorter in some cases
if it's the V6 box it will need both the front case and the input shaft swapping over from your box
Old Jul 28, 2007 | 08:27 PM
dave cos4x4's Avatar
dave cos4x4
won't the ratios be different in the transfer box aswell.
Old Jul 28, 2007 | 08:32 PM
marco polo's Avatar
marco polo
hi dave
i dont think so because they use 3.9 in the front and rear so it;s still equal on the vc
marco
Old Jul 28, 2007 | 08:33 PM
dojj's Avatar
dojj
nope
everything is exactly the same bar the output shaft on the back end, the longer bit on some boxes (as far as i know the escos boxes in particular) is so that it can fit into the different propshaft doughnut but other than that, no difference whatsoever
Old Jul 28, 2007 | 08:51 PM
xr4x4rs's Avatar
xr4x4rs
exactly the same as a saf box same fitment,transfer and gears etc
only the escos had the longer ouput shaft due to using the thinner dougnut
Old Jul 28, 2007 | 09:00 PM
dave cos4x4
so where do the different ratios come from then, the twin cam cars.
Old Jul 28, 2007 | 09:07 PM
Jasesapphy's Avatar
Jasesapphy
Yep, MT75 2wd/4wd Twin Cam ratios different
Old Jul 28, 2007 | 09:12 PM
dave cos4x4
i'm getting mixed up here.
what do you change to the 4x4 cossies to get the different ratios.
thought you used the step off gears in the 4x4 bos and the rear diff.....if so....what car are they from.
i thought they were off a 2.0 twin cam 4x4.
or have i had a drink or two two much.
Old Jul 28, 2007 | 09:36 PM
Jasesapphy's Avatar
Jasesapphy
fooking got me confused now
Your more confused than Scooby Doo
Old Jul 28, 2007 | 09:37 PM
Jasesapphy's Avatar
Jasesapphy
2.0 Twink has a 3.9:1 FD
2.9 V6 Has a 3.6 FD
Old Jul 28, 2007 | 09:39 PM
dave cos4x4
you got me confused first saying....
wat has 2wd got to do with 4x4's. [/b]
Old Jul 28, 2007 | 09:40 PM
Jasesapphy's Avatar
Jasesapphy
it was the Mt75 thing
Fook it, im not that arsed i dont own either i have a T5 let them sort it out
Old Jul 28, 2007 | 09:41 PM
dave cos4x4
2.9 V6 Has a 3.6 FD
so you use the 2.0 'twink' for the ratios then.
so...as my first post said....won't the ratios be different.
Old Jul 28, 2007 | 09:54 PM
xr4x4rs's Avatar
xr4x4rs
dave cos4x4
the gearboxes are exactly the same bar rwd mt75s
the diff ratios is where your getting confused
when you use a 3.9 in the rear of a cosworth if you dont change teh front aswell you will have to have a setp off gear in the transfer box to comensate to make the difference up as you will be running 2 different diff ratios
Old Jul 28, 2007 | 10:00 PM
dave cos4x4
xr4x4rs
i get ya.
that Magners gets to you after a few.
Old Jul 29, 2007 | 12:25 AM
BIGMATT1's Avatar
BIGMATT1
nice one for all the help with this one just hope i can get either the cossy or the rs turbo ready for ford fair
Old Jul 29, 2007 | 08:57 PM
dojj's Avatar
dojj
the normal rwd ratio's are 3.92:1 or 3.64:1
the 4wd cars use a 3.92:1 on the dohc cars only, be they badged xr or ghia
the rest of the range used a 3.62:1 diff front and rear
BUT
even though the 2.8 sierra's used the same ratio's, you cannot retro fit the 2.8 front diff onto the other 3 sorts of sumps (2.0 twinky, 2.0 cossy or 2.9 12V V6) because it's different and don't fit, even though some peole will tell you that it does
Old Jul 30, 2007 | 02:52 AM
RS500/364's Avatar
RS500/364
Got my old one here with a 50p size hole in the outbellhousing
were the clutch shatters open to offers
matman
Sep 9, 2015 05:45 PM
cossie4x4
Aug 14, 2015 06:29 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
