Apexi boost controller help pls.......
Old Jul 28, 2007 | 01:45 PM
Daz_Crystal Blue Saph's Avatar
Default Apexi boost controller help pls.......
Does anyone know if a 2WD '88 saph uses a speed signal wire?? If so/not where does the white wire on the AVC-R go to???
Old Jul 28, 2007 | 01:47 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Cossie's are cable speedo, aren't they?
Old Jul 28, 2007 | 01:50 PM
Yes, so any clues where the white wire goes??
Old Jul 28, 2007 | 01:53 PM
Christian and Beccy
#1 in Spelling Club
If the white wire is the speed signal (can't remember from memory), then you can't use the speed-related features, such as gear-based boost etc. Not essential though.
On the RST, we can use an adaptor from an EFi car (or one with a fuel computer) which screws inline with the speedo cable and give a signal output. Not sure what you can do on the Cossie though. There must be a similar way.
Old Jul 28, 2007 | 01:55 PM
Ok mate, thanks......
Daz
Old Jul 28, 2007 | 04:47 PM
polly_x's Avatar
polly_x
Use a basics hall sensor (about 20 quid from farnell) and wire it up as your speed sensor feeding the white wire.
Mine counts the drive shaft bolts on the inner joint. It does not really matter if you get the speed spot on but it will enable you to use the speed related features.
Hope that helps.
Old Jul 28, 2007 | 06:43 PM
Fiecos Dan's Avatar
Fiecos Dan
As Christian said,
Get a FRST speed sensor, as it will fit and then fit the speedo cable back.
Old Jul 28, 2007 | 08:10 PM
Ok thanks for that, where does anyone recommend as the best place to fit the pressure sensor???
Ta
Daz
Old Jul 28, 2007 | 08:17 PM
GUZZLER's Avatar
GUZZLER
Ta
Daz
i fitted my pressure sensor on the back of the slam panel & tee'd the pipe into the pressure reg pipe.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
