Fuel Rail Q
Old Jul 27, 2007 | 07:39 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default Fuel Rail Q
How do i remove ringed part and will it fit onto a 4wd fuel rail?
Old Jul 27, 2007 | 07:41 PM
You need a 10mm fuel line uncoupler/remover, also the same as a air con one, about £10/15 a set of four normally.
You can do it without with a bit of 20gauge(0.9mm) metal wrapped around like a coil shape so it springs the internal snap apart.
Old Jul 27, 2007 | 07:44 PM
Dicko&Vacant
bugger
Old Jul 27, 2007 | 07:57 PM
focusv8's Avatar
focusv8
Or a bit of 15mm copper pipe, chamfer one end on the outside then split it down it's length. open up, squash back onto fitting and push into fitting to release the spring whilst pulling the 2 halves of fittings apart.
Old Jul 27, 2007 | 08:00 PM
Dicko&Vacant
so there aint an easy solution
Old Jul 28, 2007 | 05:30 AM
It is easy if you do the above or buy the proper tool!!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
