What are DS2500 pads like?
Old Jul 27, 2007 | 01:03 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default What are DS2500 pads like?
Who uses them
any good?
Old Jul 27, 2007 | 01:06 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
err.....................good......front and back......
Old Jul 27, 2007 | 01:07 PM
JTECH James
Passion for Fords!
i just wanted to see if i got any negative replies about them i use them and think they are among the best pads out there
Old Jul 27, 2007 | 01:11 PM
pete mcrash
oh ok then.......................fuckn shite.........................is that better....
JTECH James
Passion for Fords!
Old Jul 27, 2007 | 01:14 PM
Jonzy's Avatar
Jonzy
I've heard mostly good about them, a few bad things too. I had a bad experience and gone back to mintex c-tech pads, just prefer the bite on the ctechs vs ds2500's
Old Jul 27, 2007 | 01:15 PM
JTECH James
Passion for Fords!
Old Jul 27, 2007 | 01:42 PM
Nash's Avatar
Nash
Cake lover!
I use them and have no complaints about them, i am going to get a set of DS3000's for track days though.
Old Jul 27, 2007 | 01:43 PM
I have used DS2000/2500, but did not like them at all.
I found they faded too easily and had a very dead feel to them, took a lot of warming up before worked decently.
I changed to EBC REDSTUFF CERAMIC, they are way better, apart from being dustier, plenty of feel, only faded once.
Have also used over the years Mintex 1144 1155, Pagid.
Old Jul 27, 2007 | 01:46 PM
Jonzy's Avatar
Jonzy
Exactly my findings
Old Jul 27, 2007 | 01:52 PM
Ridgey's Avatar
Ridgey
Found them very very good, from bite to extended use. Will be staying with them
Regularly supplied with large AP kits, so can't be bad.
Old Jul 27, 2007 | 02:26 PM
boXXer's Avatar
boXXer
GASH!
i have them and find they are brilliant, even better when they have warmed up.
Old Jul 27, 2007 | 02:29 PM
Redkop's Avatar
Redkop
Very good pads... never any fade during a full day on track
Old Jul 27, 2007 | 02:30 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The DS2000 material wasn't really up to the job on heavy Cosworths, hence why it was discontinued some years ago from the whole Ferodo range.
The DS2500s are also really only fast-road pads and to be any good in a Cossie, it is essential that they have good fluid (high wet boiling point) and braided hoses. On track, you will still find them a little wanting though, if used with the OE Ford 2wd calipers, due to the fact that these are cast (pig) iron and just cannot dissipate any heat, so put all this into the pads, and the DS2500 material can't take it and overheat.
The DS2500 is okay on alloy calipers and seems to perform better the bigger the discs (due to better heat dissipation), but for track use, I would use the DS3000s if Ferodo was to be your referred choice.
I have always steered clear of EBC products due to the infamous disc warping issues that the Greenstuff pads cause. However, I have only ever heard good reports about the Redstuff, so given Tab's experience, it has got to be on the list of pads to consider . I find the Mintex pads to be "squeely".
Old Jul 27, 2007 | 02:57 PM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
I used DS2500 on my S2 when it had 315mm ap 4pots, and never ever had a problem. They used to squeal a bit when cold, but i did approx 6 -8 track days per set of pads.
I did try some pagid blues, but couldnt get enough heat into them and found them crap in comparrison , but i suspect it was because my car was light - they used to work fine on everyones cossies but they are heavier !
In fact on the new track day shitter i'v brought, i'll be using the 2500's again, just in the standard calipers.
Old Jul 27, 2007 | 03:03 PM
Mike Rainbird
Caraholic
Yep, with lighter cars, you can get away with much softer pads / smaller discs etc .
Old Jul 27, 2007 | 03:25 PM
Andreas's Avatar
Andreas
I havent tried that many brands but among standard ford and mintex i found them very good for my 4x4 sapphire. Never had any problems with fade on a trackday but it has to be said im like driving miss daisy out there compared to the good drivers.
Old Jul 27, 2007 | 04:38 PM
dave cos4x4's Avatar
dave cos4x4
i used the redstuff pads on Bedford and they were really good,no complaints at all.
i used the ds2500's at Donno and i was pushing the car hard and i never had brake fade,locked up once or twice but they were really good.
i have got ds3000 as a spare set for track so i will be trying them out next i think.
Old Jul 27, 2007 | 04:39 PM
Physio's Avatar
Physio
I use them in the evo with AP 6 pots & they stop well but they seem to be really squeaky.
Old Jul 27, 2007 | 04:42 PM
Mike Rainbird
Caraholic
Did you remember to put copper slip on the backs of the pads?
Old Jul 27, 2007 | 04:45 PM
Physio's Avatar
Physio
Yes Mike but they still squeak
I probably haven't put enough on.
Old Jul 27, 2007 | 04:49 PM
Mike Rainbird
Caraholic
Are you sure that it isn't you, as you squeak when you walk, so squeaking when you pressed the brake peddle would seem to make sense .
Old Jul 27, 2007 | 04:50 PM
Physio's Avatar
Physio
You coooont
Im not that tight
Old Jul 27, 2007 | 06:02 PM
Fiecos Dan's Avatar
Fiecos Dan
i use them in my cossie, and are great for road and track. (need slight warming up to get to best, but after the 1st junction they are fine)
with 6 pot Ap's, 330mm and dot 4.
Old Jul 27, 2007 | 06:30 PM
edd's Avatar
edd
i thought they were the bollocks/ unlike EBC fucking shitty crap pants pads.
Old Jul 28, 2007 | 12:20 PM
col cos1's Avatar
col cos1
i use them and seem good changed from redstuff pads....they are that hard they wear the disc out first
Old Jul 28, 2007 | 03:04 PM
kingycos's Avatar
kingycos
Had them on my saab aero running 300bhp, best pad ive used, but a nightmare to fit...
Old Jul 28, 2007 | 10:58 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Loved them (DS2500s) front and rear on my standard 4*4 Cossie discs and calipers. Never faded. Worked well all the time, hot or cold.
Gutted when I went for the Compbrakes that DS2500s don't fit - although the supplied Hawk pads were also good if bloody heavy on the dust!
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
yatta
May 21, 2016 10:31 PM
Nov 1, 2015 06:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
mint_s2
Sep 2, 2015 08:58 AM
