suspension help non ford
Old Jul 26, 2007 | 09:33 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default suspension help non ford
My little bro's best mate has bought himself a saxo vtr, and has asked Lee to fit it for him
how hard are they to do with it being a torsion bar?
there are instructions but might as well be talking swahili
Are they pretty straightforward? Anyone give us any tips?
Sarah
Old Jul 26, 2007 | 09:34 PM
Rab's Avatar
Rab
Fucking superstar........
The rears are actually pretty easy!
About 40 minutes and job done. Fronts are a pain in the arse though...
Old Jul 26, 2007 | 09:36 PM
Dicko&Vacant
the front doesnt bother me, the springs look huge though
so whats the crack with having to measure bits
Old Jul 26, 2007 | 09:38 PM
Rab's Avatar
Rab
PS
Here is a how to!
http://www.suzukituning.com/PSA/Suspension/Lowering.htm
Old Jul 26, 2007 | 09:39 PM
Rab's Avatar
Rab
Count the splines mate.
2 splines is 40mm, 3 is 60mm etc etc.
Old Jul 26, 2007 | 09:41 PM
Dicko&Vacant
cheers, when i get stuck ill pm you
Old Jul 26, 2007 | 09:51 PM
Rab's Avatar
Rab
After you've done it you'll realise it's really a piece of piss!
The fronts are a different story
The strut IS the hib etc. I found it easier to compress the spring in situ and then drop the whole front assembly down and then get the new lowered spring on with everything still bolted up.. Except the top mount of course.
Old Jul 26, 2007 | 11:16 PM
Doug's Avatar
Doug
As Rab sais 1 spline = 20mm drop on the torsion bar as long as the torx bolt and offset washer are not siezed piece of piss .
Regards Doug .
Old Jul 27, 2007 | 09:27 AM
nilrem's Avatar
nilrem
STOP!... Carry on
front is a ball ache when the top mounts are siezed! as RAB said... drop the entire front down, then its easyter... its a ball ache to get the shock off otherwise...
Old Jul 27, 2007 | 11:29 AM
Rab's Avatar
Rab
The first time I did it. It took 40 minutes to do the torsion bars...
And 3 hours to do the fronts
Bastard stupid french cars
borboyous
Aug 22, 2015 11:17 AM
Botts
Aug 13, 2015 04:16 PM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
