Escort RS1600i This forum is for all things about the Escort RS1600i
Benifits of a rs16i head??
Old Jul 26, 2007 | 08:07 PM
ShandzS1's Avatar
ShandzS1
Default Benifits of a rs16i head??
What difference is there between a xr3 head and a rs16i head??
Old Jul 27, 2007 | 10:40 PM
ShandzS1's Avatar
ShandzS1
any one??
Old Jul 28, 2007 | 12:57 PM
GraphiteGray's Avatar
GraphiteGray
The RSI head has larger inlet and exhaust ports then the XR3 for beter flow, you can see the difference as the XR one has square exhaust ports and the RSi ones are round. Its the equivalent of the 'stage one' moddified head that most tuning companies offer
The RSi also came with a better cam, solid lifters and double valve springs to compliment the head work
Old Jul 30, 2007 | 10:22 PM
ShandzS1's Avatar
ShandzS1
Thanks!!
Old Aug 2, 2007 | 10:49 PM
It's Czech Mate's Avatar
It's Czech Mate
Valves are the same size, the valve throats are bigger on the 16i
Solid lifters and a hotter cam
Plus its all attached to a much better car
Old Dec 19, 2007 | 11:45 PM
paprst's Avatar
paprst
I think only the exhaust ports are larger . otherwise it would need more rich mixture (fuel-air)
Old Dec 20, 2007 | 08:32 AM
It's Czech Mate
Contrary to what was said above the ports are the same size as an RST/xr3 head...the throats are a bit larger in a 16i that is all
Old Dec 20, 2007 | 11:29 PM
XR2's Avatar
XR2
Ports have been reworked on inlet and outlet to get a better flow, and they are bigger on the outlet. Never looked onto the inlet of my RSi head. It came with a hotter cam (272°), solid lifters but standard valve springs. Inlet valves have been reworked to get a better flow. And the head has been skimmed so the RSi has a compression of 9,9:1, while the XR3 with the same bottom end has only got 9,5:1
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
