Ring Compressor Sleeves.. were to buy
hi all, im needing to buy a good ring Compressor my pistons or 85mm going in a evo, ive never had to buy one b4 so not to sure
thanks
andy
thanks
andy
Just get a band one easy to use, make sure you oil and clean it before each use, DON'T overtighten you will get to know how much tension to put on.
Got mine from machine mart I think(so many years ago), about Ł10/15 from memory.
If you need any more than gentle knock, it is not set right tension wise.
Originally Posted by GARETH T
http://www.machinemart.co.uk/shop/product/details/cht257-piston-ring-compressor
perfect
perfect
ive seen a few on fleabay but not to sure about the qualityhttp://cgi.ebay.co.uk/RDG-PISTON-RIN...QQcmdZViewItem
andy
