Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
Compression Strut Kit
Old Jul 26, 2007 | 07:09 PM
NUTS RuS's Avatar
NUTS RuS
Default Compression Strut Kit
Sierra/Escort Compression Strut Kit
Now made from 1 piece CNC machined solid bar.
Not the cut/shut welded type so a far nicer and stronger construction.
Includes all hardware required for fitting ie, brackets, rose joints, spacers, nuts, bolts, washers joint ends etc.
£162 plus delivery
Converts your suspension to independant units and vastly improves turn in on the front end on both the Sierra and Escort, can aid grip levels for properly set up cars. For cars running with no ARB set up (about 70% of competition cars). These are fine for normal / fast road and competition use. The introduction of bladed ARB's are only necessary for dedicated track only cars who are intimate about shaving off seconds from lap times. For your average car that mixes track with the trip to Tesco's these are 100% fine.
The kit (most of it)
Old School Escorts now have weld on brackets etc
Old Jul 27, 2007 | 01:03 AM
THE RADMAN's Avatar
THE RADMAN
look excellent ,miles better than some so called efforts ive seen
Old Jul 27, 2007 | 04:47 PM
K.Goa's Avatar
K.Goa
Very nice! why has not the brackets been fully welded and with reinforcements like the original group A ones, I did not dare mount mine before welding..
Old Jul 27, 2007 | 06:52 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
Very nice looks like a quality kit
Might have to get a set for my car.
Old Jul 28, 2007 | 09:47 AM
NUTS RuS's Avatar
NUTS RuS
On roadcars there has to be a weak link to take away any risk of twisting the chassis if a hard hit is taken.
This used to be the tube in tubular constructed items.
On these with a solid bar we us an 8.8 strength bolt that will snap/bend first, and a bracket that is designed to give in to the impact.
If requested and subsequent use is for motorsport we fully weld the bracket and use a 12 grade bolt.
Hope that helps you understand the difference
Old Jul 29, 2007 | 12:41 PM
Mr C's Avatar
Mr C
look like a top product, are the mounting brackets and spacers at the shell mounting point rose joint available seperately what price are replacements?
Old Jul 29, 2007 | 01:11 PM
NUTS RuS's Avatar
NUTS RuS
Everything is available seperatly yes (but will work out dearer to buy it that way though)
Brackets £36 pair R/J side spacers £2.75 each
Obviously cheaper if you dont want plated ones
Old Jul 29, 2007 | 03:05 PM
Fastmaul's Avatar
Fastmaul
K155MYRS
Looks good Tony!
Old Aug 29, 2007 | 02:02 AM
macca33's Avatar
macca33
Can this kit be used on your adjustable TCA?? Thanks,,
Old Aug 29, 2007 | 06:49 AM
NUTS RuS's Avatar
NUTS RuS
Yes it is designed to compliment it as part of a package
Old Aug 30, 2007 | 10:45 PM
stevieturbo's Avatar
stevieturbo
C**t
Nuts...
can you pm me with payment details/address...
shipping to Northern Ireland, although I can arrange collection if need be.
These too ??
Old Aug 30, 2007 | 11:39 PM
NUTS RuS's Avatar
NUTS RuS
PM sent
Seem to be Very popular in Ireland
Old Aug 30, 2007 | 11:45 PM
stevieturbo
C**t
Originally Posted by NUTS RuS
PM sent
Cos we all daft here !!! lol
Old Aug 31, 2007 | 12:55 AM
macca33's Avatar
macca33
Originally Posted by stevieturbo
Nuts...
These too ??
Yes stev want them both!!
Old Sep 19, 2007 | 09:12 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
I take it you remove the front ARB to fit theese?
Just thinking if I have a set of theese for my escos I can put the escos ARB on my saff?
Old Sep 19, 2007 | 09:32 PM
NUTS RuS's Avatar
NUTS RuS
Yes mate the kit does away with the ARB at the front,but obviously still keeps the rear
Old Sep 22, 2007 | 05:01 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Tony;
I apologise for going off topic slightly,but i have a 909 front suspension setup comprising of 909 coilovers,grpa. 4x4 hubs,909 tca's,and 909 compression struts.,but i think the setup is for gravel as it was removed from nigel Worswicks old saff,and the bladed roll bar was not on the car when removed,but i remember the shell had the compression strut brackets bolted to the shell using original bolts,but also seam welded to the car.
i want to bolt the setup to my saff track car,but i was concerned about;
(A) Where could i get the brackets that bolt to the arb points for the compression struts,and
(B) Would i need a bladed roll bar for this setup on track,
as the car will have 180 bhp at most,and goes round a track o.k. on the standard stuff plus koni's.
I also have the rear setup of 909 coilovers,and rose jointed beam,plus i have a rear diff cover that incorporates the diff mount.
I really want to use this setup on my car for track days as i want to make the car go better,but i'm unsure if it is suitable.
Please help me.
Old Sep 24, 2007 | 01:00 AM
NUTS RuS's Avatar
NUTS RuS
Sounds like it will be perfectly suitable.
Nigel also used to run Q27 on tarmac events too and I never remembered it having any front ARB fitted (bladed or not), so I guess thats why you havn't got it lol
What help do you need ?
Old Sep 24, 2007 | 08:11 PM
BRIGSPORT's Avatar
BRIGSPORT
I just needed the advice on wether what i have got is suitable for track use in it's current guise.
I plan to fit it to my 92 saff lx track car,but wasn't planning on putting a cage in,will the shell self destruct with everything being solid mounted?
Oh and thanks for taking the time to reply.
Old Sep 24, 2007 | 10:44 PM
NUTS RuS's Avatar
NUTS RuS
Try to find out what spec billies you have in the struts - it will be stamped on the insert, that will help determine suitability.
Springs can be changed to suit these if needed.
Old Sep 25, 2007 | 06:40 PM
BRIGSPORT's Avatar
BRIGSPORT
cheers pal.
Old Sep 29, 2007 | 02:17 PM
xr4x4rs's Avatar
xr4x4rs
i know this is going to sound stupid
but what effects does the car have when you remove the roll bar and fit these
im just confused at the min as doesnt the roll bar basically keep the shell from twisting in a sort of way as its all linked together
Old Sep 29, 2007 | 04:01 PM
NUTS RuS's Avatar
NUTS RuS
No not really dont forget you still have things mounted in the same place.
The twist (or cornering force) is taken out by the dampers that now work independantly from each other. As long as they are not knackered 20 odd year old items it will be 100% fine.
An ARB will not stop a shell from twisting as it is basically acting just like a spring. The rear ARB is left untouched anyway but some race cars do disconnect it sometimes to change the way the car steers.
Old Sep 29, 2007 | 04:08 PM
xr4x4rs's Avatar
xr4x4rs
what are the benefits of these aswell
as im rebuiling the engine the car isnt coming back on the road until its 90% finished now, inc new brakes and adjustable tca, would i benefit from these?
Old Sep 29, 2007 | 05:14 PM
NUTS RuS's Avatar
NUTS RuS
As with anything adjustable the benefits are in the actual set-up of the components and not necessarily the components themselves.
If you know what or how you want the car to perform then these will assist you to get that set up. They are not a new thing and have been used in competition for years.
Old Sep 29, 2007 | 05:17 PM
xr4x4rs's Avatar
xr4x4rs
the car is mainly a road car, but i do hope to get it on track somepoint and the strip aswell
will keep them in mind
was just concerned about losing my roll bar
Old Sep 29, 2007 | 05:24 PM
NUTS RuS's Avatar
NUTS RuS
With the increased grip and better cornering gained you wont be worried about your roll bar for too long
Old Oct 2, 2007 | 03:44 PM
K.Goa's Avatar
K.Goa
Not a very big deal to mount a front ARB anyway, so you can get away with softer front springs in stead of using stiffer springs to counter te bodyroll.
Old Oct 3, 2007 | 08:23 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
are these going to be available for all escorts soon ie mk 1,2,3 + 4 etc ??????.
Old Oct 3, 2007 | 08:28 PM
rapidcossie's Avatar
rapidcossie
I have tried a similar set up on my car and didnt notice any increase in body roll.
Old Oct 4, 2007 | 04:09 AM
NUTS RuS's Avatar
NUTS RuS
Escort 1 & 2 ones are now ready (uses a weld on bracket)
Escort 3 already has them
Escort 4 - no plans for production due to the location of the gearbox crossmember.
Old Oct 4, 2007 | 06:51 PM
Alex_86's Avatar
Alex_86
i could be a test person for you if you want to make mk4´s
Old Oct 8, 2007 | 05:24 PM
RWD_cossie_wil
is it possible to refit the roll bar infront of the front x-member group A style, or not really worth it?
Old Oct 8, 2007 | 09:25 PM
NUTS RuS's Avatar
NUTS RuS
Mods would be needed to the chassis and the TCA's would need modifying to accept new drop links etc.
For not a great deal of gain its a lot of work, but nothings ever impossible.
It was a next step mod to eeeak out another '00 second saving on lap times by the circuit racers.
Old Oct 18, 2007 | 03:54 PM
K.Goa's Avatar
K.Goa
think I gave about 300 quid for my front rollbar, easy to mount, but reqires a bit of welding.
Old Oct 20, 2007 | 09:45 AM
richard youll's Avatar
richard youll
i have put these on my saff and run avo coil overs re valved to 280 120 and have noticed the handling on the front is remarkable, i cant remember what castor i set them to but it turns in so well the only thing i have found is the rear end feeling unstable because it cant cope with how good the front is , so i need an adjustable rear beam now but highly recomended i'd say!
Old Oct 22, 2007 | 08:10 PM
NUTS RuS's Avatar
NUTS RuS
We often get emails back saying similar Richard.
Many people also notice a difference in braking peformance as well as steering response as the uprights are now under proper compression and not tied to a sprung bar.
Old Oct 22, 2007 | 10:44 PM
RWD_cossie_wil
stop it I can't afford theese just yet but want a set - do they take paypal/ credit cards?
Old Oct 26, 2007 | 12:18 PM
NUTS RuS's Avatar
NUTS RuS
Can do cards over the phone Yes
But if you can't afford it I won't
You could always buy half the kit this month and the other half half next month
Old Oct 26, 2007 | 05:35 PM
RWD_cossie_wil
The amount I have spent on my car this last few months is shocking , not a long way off 5 figures
