balls
Old Jul 26, 2007 | 05:10 PM
piranha's Avatar
piranha
Default balls
bugger.
my xr4x4 had the gaskets missing on one of the exhaust manifolds. tried remove the manifolds and managed to shear one of the studs off,
can't drill it out in situe. so it's either leave it sounding like a tractor (not much worse than it has been without the gaskets!!), remove the head and drill the stud out or leave it and get a shift onwith the 24v cossie conversion.
the only problem is I have no spare time and i'm skint.
Old Jul 27, 2007 | 11:02 AM
mark's Avatar
mark
thay dident have gaskets from new
for the time fooking abobut with the head you might aswell drop the 24v in it lol
Old Jul 27, 2007 | 06:07 PM
piranha's Avatar
piranha
the side with gaskets is quite, the side without gaskets is really noisy (obviously worse now ) which says to me it needs gaskets
and they are listed as a part for this model of car at our local motor factors place
but you are probably right the 24v conversion would be time better spent.
Old Jul 27, 2007 | 10:41 PM
mark's Avatar
mark
lol yep forgot to add once thay come off you have to use gaskets
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
martynhomer01
14
Sep 23, 2015 12:23 AM
21
Sep 14, 2015 06:38 PM
Mark V8
Sep 13, 2015 09:34 AM
