This week, I will be mostly...
Old Jul 26, 2007 | 12:41 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default This week, I will be mostly...
...advertising the Alumec diff strengthening plate:
[/quote]
As fitted to Lee (AKA Porkie's 600bhp Sierra), so I hope it performs okay .
http://www.randbmotorsport.co.uk/sho...?ProductID=338
Old Jul 26, 2007 | 12:44 PM
Matt's Avatar
Matt
you shouldnt be doing so in general discussion mr moderator so stfu
Old Jul 26, 2007 | 12:46 PM
rog's Avatar
rog
Is that the 710 ON version.......
Looks good, i looked into these a while ago, will see when i get my car running, just how easy the diff breaks to see if i need one.
Chip's Avatar
Chip
*** Sierra RS Custard ***
Paid up traders are allowed 1 advert in GD
Old Jul 26, 2007 | 12:47 PM
Chip's Avatar
Chip
LMAO @ "710 ON"
Old Jul 26, 2007 | 12:48 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
I'm being dumb, But is that the rear diff
Plate looks good anyway
Old Jul 26, 2007 | 12:52 PM
Billabong's Avatar
Billabong
Front...
foreigneRS's Avatar
foreigneRS
Testing the future
do you fill it up via the 710 cap?
Old Jul 26, 2007 | 12:54 PM
Charlie Chalk
Unknown.
cheers Bill
Old Jul 26, 2007 | 01:17 PM
Disabled Account's Avatar
Disabled Account
Default Re: This week, I will be mostly...
For those that think the standard front diff cover must be "plenty strong enough for the job", so why buy one of Mike's?
Exhibit 1:
Old Jul 26, 2007 | 01:20 PM
Chip's Avatar
Chip
is that the chicken or the egg though doug?
Old Jul 26, 2007 | 01:23 PM
Mike Rainbird
Caraholic
I suggest you read the trader's rules - in the meantime, have one of these .
Old Jul 26, 2007 | 01:28 PM
boXXer's Avatar
boXXer
GASH!
how do they break just the cover plates though
Old Jul 26, 2007 | 01:33 PM
Mike Rainbird
Caraholic
They don't, they break the casing as well! However, these strengthening plates are designed to prevent the casing from flexing enough to do that .
Old Jul 26, 2007 | 01:34 PM
Disabled Account
It's a chicken with egg on it's face
Actually I dont know. But a well designed diff strengthening plate or a complete replacement cover like Mike's will make the whole assembly much more ridgid and less likely to twist & fail even if the CWP does break up.
Old Jul 26, 2007 | 01:37 PM
Chip's Avatar
Chip
Indeed
Old Jul 26, 2007 | 01:51 PM
boXXer's Avatar
boXXer
GASH!
ahhhh right.
Old Jul 26, 2007 | 01:54 PM
Porkie's Avatar
Porkie
Obviously I am not that technical mate...
But I am pretty sure thats a standard Ford diff cover
HTH
Old Jul 26, 2007 | 02:17 PM
lead_foot's Avatar
lead_foot
is awesome
Looks up to the job.
Old Jul 26, 2007 | 02:49 PM
Magic Numbers's Avatar
Magic Numbers
Looking good
Old Jul 26, 2007 | 03:28 PM
Mike Rainbird
Caraholic
Originally Posted by EsCosRacer
i have one thats drilled / tapped etc. to accept oil pressure sender as well as pump out and thermostat must say it did look appealing before the modification
And instead, now you have no ground clearance .
Old Jul 26, 2007 | 03:44 PM
Bullett's Avatar
Bullett
i take it these fit saff and escy?
when would you need one really?
Old Jul 26, 2007 | 03:51 PM
Porkie's Avatar
Porkie
On a standard diff casing?? probably a good idea over 350bhp??
on a Thickwall case like mine?? probably over 450bhp??
I am guessing though to be honest.
I always think preventation is better than cure....
Mike does a cheaper plate as well though and for the amount it costs, I would put one on anything over standard power really for piece of mind!
Even if you have a Thickwall case its well worth putting a plate in at least if you don't want to stretch to the full cover
Old Jul 26, 2007 | 03:55 PM
Mike Rainbird
Caraholic
Mike,
Sorry, I stand corrected, and providing you keep the ride height like this, you won't have any problems .
Also, until you car is fully equipped, I wouldn't speak too soon about the weight .
If you have over 350bhp and want to go launching or if you have shed loads of torque and go on track with slicks.
Old Jul 26, 2007 | 04:25 PM
Bullett's Avatar
Bullett
Porkie
agree with you there on prevention thing
Mike Rainbird
so if you have one of these on a shot peened diff and the box is either a mullet or quaife what do you do when you go launching it and a driveshaft snaps?as thats next in line isnt it?
Old Jul 26, 2007 | 04:26 PM
Porkie's Avatar
Porkie
Old Jul 27, 2007 | 07:37 AM
Mike Rainbird
Caraholic
be glad my engine is not done for ford fair...so u can indulge a few more weeks in your illusions
Is this the same as when you were going to hand my arse to me at Karting, and then got lapped five times in 30 mins ?
Porkie
Mike Rainbird
Replace them with some uprate GKN ones .
Old Jul 27, 2007 | 10:25 AM
Smit's Avatar
Smit
The 60ft Launch King
Looks smart
Old Jul 27, 2007 | 03:57 PM
xr4x4rs's Avatar
xr4x4rs
didnt these used to have a screw in the middle for oil drain? as i thought that was quite a good idea
Old Jul 27, 2007 | 04:02 PM
GARETH T's Avatar
GARETH T
looks very well made i would of used a ball nose cutter on the inner releaf
Old Jul 27, 2007 | 04:11 PM
lead_foot's Avatar
lead_foot
is awesome
I would of used a fillet endmill cutter for the inner releaf
Old Jul 27, 2007 | 04:13 PM
GARETH T's Avatar
GARETH T
i couldnt think of the propper name for them
Old Jul 27, 2007 | 04:45 PM
Mike Rainbird
Caraholic
no mike, that was to keep you happy cause your car broke on the ring, remember ?
So what about all the other people that lapped you that didn't even take their car?
Old Jul 27, 2007 | 05:19 PM
GARETH T's Avatar
GARETH T
get a room you gigolo and rent boy
Old Jul 27, 2007 | 05:20 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Mike why dont these come with a bung in them so the oil can be changed without removing the whole cover as it is quite messy, is it a strength issue ,as i have had one put into mine with a steel plate, and have had no issues and i dont get covered in oil ,and it doesnt take me long to change the oil!
