overboosting 3 dr????
Old Jul 25, 2007 | 07:16 PM
cossiedrift's Avatar
cossiedrift
Default overboosting 3 dr????
my 3dr is over boosting 2.5 bar on gauge. i have checked all pipes and they seem ok and the amal valve is clicking on and off with ignition. anyone have any idears what it could be?
thanks danny
Old Jul 25, 2007 | 07:19 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
what should it be boosting at?
sounds like the actuator pipe has come off!
Old Jul 25, 2007 | 07:24 PM
cossiedrift
should peak at 25 psi then hold about 20
Old Jul 25, 2007 | 07:25 PM
JTECH James
Passion for Fords!
are you double sure there isnt a split in any of the boost control hoses, wastegate actuator to amal, and amal to compressor housing
because for some reason the actuator isnt seeing the boost from the compressor housing, or if it is the gate isnt opening
the next step would be to run a pipe from wastegate actuator to compressor housing, this will bypass the amal valve and see if that stops it
if not ping the arm off the wastegate and make sure its free to move
Old Jul 25, 2007 | 07:45 PM
cossiedrift
the arm is free to move might get some new hoses tommorow then i know for sure. could it be the actuator give up?
Old Jul 25, 2007 | 07:47 PM
JTECH James
Passion for Fords!
it is possible it it seized up and wont move ,but ive never heard of that before,
just put a hose between the actuator and comp housing so you KNOW the wastegate actuator is seeing boost pressure first
Old Jul 25, 2007 | 07:52 PM
cossiedrift
what do that then drive it? what should it do?
Old Jul 25, 2007 | 07:54 PM
JTECH James
Passion for Fords!
yeah drive it ,and the gate should open at whatever its been pre loaded to, all you wont have is the spike which is caused by the amal valve
if it works you know its amal or a hose, if it doesnt it must be the wastegate actuator
it wont do any damage, if it works it will run less boost than when it was working fine! if it doesnt it will overboost again!
Old Jul 25, 2007 | 07:56 PM
cossiedrift
ahh i see i will try that tommorow thanks for that mate
TIFF
Jan 1, 2006 10:15 AM
jonny gav
Ford Focus RS
Jun 8, 2005 11:27 AM
007
Nov 14, 2004 05:15 PM
TurboBlower
Oct 15, 2003 10:49 AM
