Difference between injectors - tech help
Old Jul 25, 2007 | 06:10 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default Difference between injectors - tech help
Right i want to know the advantages and disadvantages of using Siemens 83lb injectors over Bosch Grey 403's?
Apart from the obvious power capability......
What will fuel consumption be compared against each other, and is there anything else significant i should be aware of?
Thanks
Old Jul 25, 2007 | 06:53 PM
Dicko&Vacant
anyone
Old Jul 25, 2007 | 07:14 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
the siemens 55lb are a closer flow rate to the grey,
as far as i am aware the siemens injectors have a better spray pattern,
as for fuel consumption it would depend on the map and software
i run the 55lbs on mine ,love em, and on closed loop can see up to 38mpg
Old Jul 25, 2007 | 07:54 PM
Dicko&Vacant
cheers any other advantages?
Old Jul 25, 2007 | 07:59 PM
JTECH James
Passion for Fords!
well the siemens ones are just a simple fit,
and the greys have all the cap issues ,fit or not, drill or not and need a fitting kit
speak to stu at MSD he sells them and maps them ,he will tell you if they are sutable for your application
Old Jul 25, 2007 | 08:00 PM
Stu @ M Developments's Avatar
PassionFords Creator
83lb injectors at 400bhp are using less injector duration that the YB did as a nice standard unmodified car so are literally having a holiday.
That said, they are having an easy time at 500 bhp too.
That equates to RELIABILITY. What else matters?
Old Jul 25, 2007 | 08:02 PM
Dicko&Vacant
cheers stu
will the car run better with these or wont i notice much difference?
Old Jul 25, 2007 | 08:03 PM
JTECH James
Passion for Fords!
if its set up correctly now ,and set up correctly afterwards ,it would run exactly the same, but have many many more ponies
Old Jul 25, 2007 | 08:06 PM
Originally Posted by Dicko&Sarah
cheers stu
Injectors have absolutely nothing to do with either the way an engine runs or its fuel economy. Both those things are down to your ECU calibration.
If your mapper is substandard, both those criteria may be poor. If he blames injectors for either poor running or poor economy, find another one who knows what they are doing with your particular management.
Finally, never have an engine where the turbo can either match, or out flow the injectors. Its a foolish choice to make.
Old Jul 25, 2007 | 08:08 PM
JTECH James
Passion for Fords!
i know when richie B9KOS came back from your place stu ,on 83lbs and a T38 he said they were running a 32% or 33% duty cycle
happy days!
Old Jul 25, 2007 | 08:27 PM
Dicko&Vacant
cheers stu
so will the t4 be ok on 83lb injectors i presume so
cheers
Old Jul 25, 2007 | 08:30 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
cheers stu
cheers
Well yes they should be ok but dont take a non-pro's word for it
Old Jul 25, 2007 | 08:59 PM
JTECH James
Passion for Fords!
yes a t4 will run fine on the 83lbs,
not quite enough on the 55lbs
im not a pro but asked stu a very similar question a few weeks ago
mk3ste
Oct 17, 2021 10:09 AM
wowk
Mar 30, 2021 07:49 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
