Crank sensor wire, where does it go...
Ok I have to put all the bits back on my engine (cossie), but for the life of me i can't remember which way the wires run, i.e. does the wire get bolted to the sump using that bracket, and the connectors onto the side of the block????
If anyone has pics that would be alot easier.
Rog.
Rog.
PassionFords Creator
Originally Posted by JjCoDeX75
Sexy lookin engine, Stu!
JJ
JJ
Better looking than most women IMO.
Ok cheers, so that bracket bolts onto the sump.
There is a bracket for the crank sensor/knock sensor multiplug sensor multiplug, that goes under the inlet manifold? Also, i have amended the pic you posted, the bit i have circled, on my block it has a plate that goes over it, does this have a gasket, and what exatly is it for anyway????
Thanks alot for your help!
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
22
Sep 24, 2015 08:14 PM
Si B
Sep 12, 2015 06:49 AM
