Best way to modify spring platform on Konis
Old Jul 20, 2007 | 08:18 PM
MATCOS's Avatar
MATCOS
Default Best way to modify spring platform on Konis
For extra clearance when fitting bigger/wider wheels
any pics please guys, can they be cut (like an RS500 battery tray)
I am doing mine this weekend and welcome your suggestions
Old Jul 20, 2007 | 08:59 PM
THE RADMAN's Avatar
THE RADMAN
are yours like this mat, or the earlier type
Old Jul 20, 2007 | 09:01 PM
THE RADMAN's Avatar
THE RADMAN
i had some that ggr had done once and they just used an angle grinder to cut off the lower part at 45 degree angle then welded a flat piece of steel on to fill the hole, it depends on how much modding is reqd
Old Jul 20, 2007 | 10:12 PM
MATCOS's Avatar
MATCOS
Mine are old style by the looks of it even though they are only a few years old -I need to fit my 235 tyres on and may need to get medieval on their asses
Old Jul 20, 2007 | 10:52 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
just chamfer them with an angle grinder like the pic above I did exactly the same with mine 225-40R18s on Rondells
Old Jul 21, 2007 | 02:12 AM
MONSTER's Avatar
MONSTER
I used a 5mm spacer Mat. let me know if you need some as i've a spare pair
Old Jul 21, 2007 | 09:23 AM
MATCOS's Avatar
MATCOS
Mine are 235's and they are Toyo R888's so they have a very square side wall and are that bit wider than 225's I think I might have to cut off quite a bit
to get them to clear with space
Old Jul 21, 2007 | 09:24 AM
MATCOS's Avatar
MATCOS
Cheers for the offer Dave, I will have a go this weekend with a big hammer and see how I get on first
Old Jul 21, 2007 | 09:49 AM
THE RADMAN's Avatar
THE RADMAN
like dave says it may be a lot quicker to just use some small spacers
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
truffleshuffle
Sep 10, 2015 09:35 PM
