Series 2 misfire
Old Jul 17, 2007 | 04:07 PM
PeteS2RST's Avatar
PeteS2RST
Default Series 2 misfire
My series two has developed a misfire when under load and doing 2500rpm or more. it idles fine. has checked plugs and done a comp test while i was at it this was fine too any ideas on what else i should be checking?
Thank in advance for any help
Pete
Old Jul 17, 2007 | 08:20 PM
homer j's Avatar
homer j
check the rotor arm and dizzy cap for signs of pitting and arcing. if in doubt change them. don't forget as well that it could be a lead breaking down or even the plug electrodes breking down inside the plug.
Old Jul 17, 2007 | 09:45 PM
mercury grey minter's Avatar
mercury grey minter
Fuel pump.
Old Jul 17, 2007 | 10:26 PM
MarkXr's Avatar
MarkXr
Had this a couple of days ago and it was a worn fuel pump. Exchanged for another one and drove fine again.
Not saying this is your problem but could be......
Old Jul 31, 2007 | 07:53 PM
PeteS2RST's Avatar
PeteS2RST
Right i checked all ignition components and they were all fine so put a new fuel pump on and then found i wasn't getting any fuel out of the no. 2 injector so changed that as well. car has been spot on until today it has developed the same scattered misfire as before
Any ideas anyone
Old Jul 31, 2007 | 08:28 PM
Barry R's Avatar
Barry R
mine was doing it it after i had new plugs fitted
turned out they left 1 loose, all the gaps were
to big and 1 was cracked
new plugs by myself now alls fine
Old Jul 31, 2007 | 08:29 PM
Barry R's Avatar
Barry R
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
