V6 to V8 Capri?
Old Jul 16, 2007 | 09:43 AM
Urban Legend's Avatar
Urban Legend
Default V6 to V8 Capri?
Morning guys
My bro has a 3Litre V6 essex engine in his mark 3 capri with all the V6 running gear and 4 speed gearbox.
what he wants to know is will a ford small block V8 go straight in without changing everything to v8 running gear etc?
also, anyone know the fuel consumption on a small block V8 and roughly what power that will give his as standard?
cheers
Old Jul 16, 2007 | 10:12 AM
MWF's Avatar
MWF
As far as I know a Ford small block will go in but would require the American spec T5 transmission which in turn I think needs the prop shortening.
Try looking up Capri Racing And Performance aka 'CRAP' they used to do plenty of V8 conversions for Capris.
Old Jul 16, 2007 | 12:06 PM
Small block will go in no problem.
BHP depends on year a lot(smog kit), but tune up parts are cheap and they rev well as short stroke.
It will explode the gearbox you have though, if you use VS carbs like a 650 VS you could get high 20's low 30's mpg on a run no problem.
mk1turboestate
Dec 2, 2015 08:31 PM
slammedorion
15
Nov 1, 2015 07:17 PM
jonnyenglish
Sep 21, 2015 07:31 AM
STAFFY OWNER
Sep 13, 2015 08:59 PM
Adam Graham
Sep 6, 2015 06:04 AM
