How do you remove the gear knob
Old Jul 14, 2007 | 11:14 AM
MATCOS's Avatar
MATCOS
Default How do you remove the gear knob
As above,I have now managed to remove the console but I cant get the gear knob off does it pull off or twist as it doesn't seem to want to do either
Old Jul 14, 2007 | 01:11 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
matt 2 screws if you look inside the DIN. 2 screws where the ash tray is,1 under the window switchs. then you may or may not have the 2 fastners in the footwell push the centres in and they come out this side then you can resue them after . An i think the nob is screwed as i have a monte one which is held on with a hex bolt..
if you can't work it out after that you know what you can do
Old Jul 14, 2007 | 01:36 PM
cos jon's Avatar
cos jon
mine is a 93 car and you pull it off
Old Jul 14, 2007 | 03:06 PM
THE RADMAN's Avatar
THE RADMAN
early cars ,pull off, but you will need a new one as they break the lugs, later ones unscrew
Old Jul 14, 2007 | 03:24 PM
MATCOS's Avatar
MATCOS
It's off and the new leather gaiter is fitted too
pics later
Old Jul 14, 2007 | 05:58 PM
adamski frst
bufty
Old Jul 14, 2007 | 09:38 PM
MATCOS's Avatar
MATCOS
Have you only just noticed
cossie330
Oct 7, 2015 08:22 PM
rsguy
44
Sep 29, 2015 03:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Fudgey
Sep 17, 2015 01:06 PM
