Modifying a 1.6 Focus estate.
Old Jul 13, 2007 | 08:50 PM
Farmer Giles's Avatar
Farmer Giles
Default Modifying a 1.6 Focus estate.
Thinking about making a few mods to my Focus and would like to get some info from people who know better than me..
ENGINE
With an induction kit, quality chip, de-cat exhaust, some kind of fuel pressure boost valve and a pro set up what sort of power increase could I expect. I guess the engine would be alot more responsive but only maybe 5 or 10 BHP at most ????
For the gains I would get making mechanical changes, IE cams, headwork, would it be worth it on a 1.6??? I suspect not ??
BRAKES
Are calipers and discs from faster versions, RS or ST170 for example, a straight fit onto the base models (obviously front only), assuming the wheels are big enough and do they make a huge difference over standard even when combined with braided hoses and different pads ?? Would I need the master cylinder from the doner vehicle too ??
SUSPENSION
Looking at a 30 to 40 mm drop, nothing too extreme as it's still my daily driver, but can this be achieved affectively with just lowering springs or is that just a compromise over fitting a full spring and damper kit ?? I don't want to screw the already pretty good handling.
I presume the traders on here would be able to supply anything I need in good time and at a good price and the rest I can get off of Ebay
Thanks for reading.
Martyn
Old Jul 13, 2007 | 09:20 PM
wide ka's Avatar
wide ka
i would have a look on the zsoc forum as its the same engine as the fiesta, they seem to see good power from exhaust and filters, you can tune them alot im using one in my ka and will be around 180bhp, brakes you can fit the st170 setup which is alot better, hope that helps abit!
Old Jul 13, 2007 | 09:24 PM
Benni's Avatar
Benni
Ban[B][/B]ned
YoungDan has a thread and is builidng a powerful 1.6 engine. Or powerful for the engine.
Old Jul 13, 2007 | 09:34 PM
James's Avatar
James
brakes need to chagne the hubs aswell, not worth the hassle imho unless you intend to track it?
Old Jul 13, 2007 | 09:38 PM
user 769729789's Avatar
user 769729789
Would hardly bother matey.
The time and money you would spend doing it, id say you would be aswell sourcing a 2ltr from a smashed focus and dropping it in?
155lee
Oct 27, 2015 04:55 AM
liamT74
Sep 23, 2015 10:24 PM
cozzy jeff
Sep 12, 2015 04:32 PM
Mickeystewart
Sep 9, 2015 04:04 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
