Noisy lifter problem on new engine...
Old Jul 13, 2007 | 05:12 PM
boXXer's Avatar
boXXer
GASH!
Default Noisy lifter problem on new engine...
Hello peeps.
Ive done around 850 miles on my new rebuild now, and today, one of the lifters started tapping quite noisily on tickover. It goes away as soon as the revs increase.
They were brand new from PJ Motorsport.
Will it shut up? or am i gunna have to change them again? What could be the cause?
Cheers for any info
Mike
Old Jul 13, 2007 | 05:15 PM
col cos1's Avatar
col cos1
they have a mind of their own mate
give it time they will shut up eventually
Old Jul 13, 2007 | 05:19 PM
boXXer's Avatar
boXXer
GASH!
thats good to hear.
im running pro r 15/50. Is that right? or shall i drop to 10/50?
Old Jul 13, 2007 | 05:20 PM
col cos1's Avatar
col cos1
i use castrol edge sport 10w 60,cant fault it
Old Jul 13, 2007 | 05:44 PM
rs_hole's Avatar
rs_hole
erm i think its because i had a wank in your oil cap when ur back was turned lumpy old spunk is not good for engines i hear
Old Jul 13, 2007 | 05:45 PM
boXXer's Avatar
boXXer
GASH!
you mofo.
Old Jul 13, 2007 | 05:58 PM
GARETH T's Avatar
GARETH T
Old Jul 13, 2007 | 07:56 PM
ricky_3dr's Avatar
ricky_3dr
Shut it slaaaaaaaaaaaaaaaaaaaaaaaaaag
Old Jul 13, 2007 | 08:03 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
should be good/quiet from the start.........................mine is
Old Jul 13, 2007 | 08:15 PM
boXXer's Avatar
boXXer
GASH!
just been out in it again, and its still knocking on tick over. As soon as you increase revs, it dissapears!
Old Jul 13, 2007 | 09:37 PM
boXXer's Avatar
boXXer
GASH!
thinking about it, it was fine until i changed the oil yesterday to fully-synthetic from mineral.
Would that have anything to do with it?
Old Jul 13, 2007 | 10:19 PM
boXXer's Avatar
boXXer
GASH!
anyone?
Old Jul 13, 2007 | 10:22 PM
ricky_3dr's Avatar
ricky_3dr
Probably that oil, the Saph is ticking like a bitch since a recent oil change
Old Jul 13, 2007 | 10:23 PM
boXXer's Avatar
boXXer
GASH!
Old Jul 13, 2007 | 10:34 PM
CosKev3's Avatar
CosKev3
Leave it for a few miles,but new ones shouldn't really be noisy
Might be worth takin cam cover off and checking that the threads are ok on the studs that hold the cam caps down,common for these to pull the threads out of the head
What did you torque them too,IIRC its only somethin stupid like 5 lbs ft
Old Jul 13, 2007 | 10:58 PM
boXXer's Avatar
boXXer
GASH!
yeah did as workshop manual suggested. but liek i say, its been fine until i changed the oil
Old Jul 14, 2007 | 05:07 AM
Ian M's Avatar
Ian M
seen this before it turned out to be a dodgy oil filter. worth changing it before anything else i would of thought.
Old Jul 14, 2007 | 08:54 AM
boXXer's Avatar
boXXer
GASH!
oil filter? really???
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
